Pinebook Pro - M.2 SSD specifications Please
I ordered the M.2 SSD adapter for my Pinebook Pro,
However I am hoping to get a better idea of the exact specifications I should be looking for in the SSD drive itself.
 Here is what I have found so far :
                                                        PCIe x4  M.2 NVMe
                                                        Not to exceed 2.5 watts
    However I have not seen anything about what 'Generation'  is acceptable  ?
        I have seen an abundance of  'Gen 3'  M.2 SSD's  for sale in the market place ...
        Very few have the Maximum Wattage listed,  Some have an Active Wattage,  But I do'nt think Active = Peak  ?
         Most do not even mention the wattage.
     I was hoping to find this information in the Pinebook Pro WIKI,  But it does not elaborate on the drive specs.
    *   I got the 2.5 watts from the Pine64 Info team via email, (Thank you info team ! )
    *   Is there a physical thickness spec as well ?
    *   I see one person had problem with his M.2 SSD  lifting his touch pad when he re-assembled his laptop. !
         IS there any other specs I should be aware of  Before I Order the drive  ?
            Most of my experience has been the 2.5" Laptop sata drives  and the old full size desktop drives
           THANKS  for any help & advice  !
              Smile
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
(10-03-2019, 04:08 AM)bcnaz Wrote: ...
The SoC supplies PCIe generation 2. And since generation 3 is backward comaptible with 2, any generation 2 or 3 NVME drive would work, (from this perspective). For that mater, a PCIe generation 4 drive should work, (but they are few, and probably more expensive at present).
Give the Pinebook Pro Wiki time to build up information. This is a new product. In someways, the average person should wait months until all the quirks have been either worked out, worked around or at least identified. (Not saying you are an average person who should wait...)
I too am looking for wattage information. In someways the NVME should be much faster than the eMMC, so using a NVME that is slower but meets the power budget better should okay for most people.
Arwen Evenstar
Princess of Rivendale
(10-03-2019, 04:08 AM)bcnaz Wrote:     *   Is there a physical thickness spec as well ?
There are physical specs.  Thickness was posted somewhere on this forum earlier, but I couldn't find it.  I'm not going to bother the devs with any questions at this time.
(I'm giving contributors time to add to the Wiki on their own accord, before I make note of what could be missing.)
Do you have a link to that installation problem?
Please see this thread:
https://forum.pine64.org/showthread.php?tid=7766
IS it the module hitting or is it the mounting nut that holds the module to the adapter board ?
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 4 1,105 05-06-2024, 09:27 AM
  Pinebook Pro on Debian 12 Power Issue u974615 1 472 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 417 02-17-2024, 07:06 PM
  Pinebook Pro charging issues tomekdev 1 749 01-05-2024, 08:40 PM
Last Post: tomekdev
  Replacement battery for PineBook Pro DrYak 3 1,297 11-07-2023, 10:09 AM
Last Post: DrYak
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 134,111 09-13-2023, 03:43 AM
Last Post: k3dAR
  PineBook Pro dead ottahe 9 6,317 01-18-2023, 07:41 PM
Last Post: ottahe
  Pinebook Pro malfunctioned hardware samtux 10 4,732 12-27-2022, 03:31 PM
Last Post: samtux
  PineBook Pro revision 2.2: Wishlist for the hardware issue fixes dsimic 115 141,150 11-30-2022, 04:28 PM
  Decent Pinebook Pro barrel PSU / Charger petaramesh 3 2,033 10-21-2022, 07:57 AM
Last Post: dachalife
