Problem with time in rock64
Hi, I have ubuntu Bionic 18.04 installed and I have correctly chosen the time zone but it gives me one more hour.
I try with ntp, with sudo date, but I do not change the time to the right.
What can I do to fix the problem?
(11-10-2018, 10:20 AM)gedas07 Wrote: Hi, I have ubuntu Bionic 18.04 installed and I have correctly chosen the time zone but it gives me one more hour.
Open a terminal and run:
dpkg-reconfigure tzdata
and make sure 100% sure the system has the timezone set properly.
NTP etc will only update the system with UTC, no TZ info is set etc
Also make sure you have the most current tzdata package with the most up to date TZ config
I do this
https://feeding.cloud.geek.nz/posts/time...d-systemd/
And don't works , but i leave this for a one day and now the time is correct. I don know
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 13 18,620 Yesterday, 02:43 PM
  rAudio for Rock64 V2/Pine A64+ shinzuka 11 1,694 06-25-2026, 03:16 PM
Last Post: shinzuka
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 1,086 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 5,975 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 11,864 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 3,197 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 3,379 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  problem with debian emmc boot G4zCDzWb 10 12,536 11-01-2024, 04:32 PM
Last Post: bits
  arch rock64 does not boot nemnob 1 4,367 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  DietPi OS for ROCK64 MichaIng 42 86,465 09-01-2024, 06:43 AM
Last Post: RaymondDay
