Compatible Battery Types/Brands List
#21
(03-20-2016, 12:07 PM)AUDIOTEK Wrote: OK thanks  In that Ali list above which one would you recommend?   I have to buy a battery by the end of this week!!!
I didn't tested them and can't tell the battery quality by visual, this means I will not able to recommend.
Can you recommend one just by specs?
I cannot recommend just by spec due to Lithium battery can cause fire if bad build quality.
What are the specs on the pine battery I received?
Question Z-Wave module pinout to make it compatible with Pi b+ ebretteville 59 135,652 07-12-2019, 08:55 AM
Last Post: kris240376
  What cameras are compatible with that ribbon connector? nayrenitnatsnoc 1 6,556 02-18-2017, 11:50 PM
Last Post: dkryder
  Raspberry Pi and Arduino accessories compatible? Krowyn 6 16,887 10-08-2016, 10:36 AM
Last Post: rohan
  Lithium Polymer Battery USA / CERTAIN EUROPE COUNTRIES ONLY JulianM 11 26,674 09-07-2016, 04:40 PM
Last Post: Mednar
  General Battery Questions nspireing 11 26,159 07-03-2016, 03:15 AM
Last Post: pfeerick
Question lipo battery boot issue Luke 5 12,944 05-29-2016, 02:13 PM
Last Post: Luke
  RTC battery steve8939 2 7,483 05-25-2016, 04:58 PM
Last Post: steve8939
Question Camera / Lcd / Battery documentation soufyen 1 5,765 04-29-2016, 03:24 PM
Lightbulb What is the third battery pin for? combs 1 6,204 04-20-2016, 04:39 PM
Last Post: rahlquist
  Zwave AU compatible mist42nz 1 5,456 03-23-2016, 04:00 AM
Last Post: Ghost
