Compatible Battery Types/Brands List
I'm in Canada and cannot get the battery shipped to me and there's seems to be lots of confusion on which batteries will work.   Can we get a list of compatible batteries with links so we can order them easily? Ebay links would be great Big Grin  .
Another question does the AC to DC PSU actually charge the battery as well?
(02-18-2016, 10:00 PM)AUDIOTEK Wrote: I'm in Canada and cannot get the battery shipped to me and there's seems to be lots of confusion on which batteries will work.   Can we get a list of compatible batteries with links so we can order them easily? Ebay links would be great Big Grin  .
Any 3.7V lithium or LiPo battery will work. If possible, get the one that have temperature sensor build in for safety reason.
The PSU also charge the Lithium battery but not RTC battery.
Thanks TL. What type of connector should the LiPo battery have?
So any of those will work?
http://www.ebay.ca/sch/i.html?_from=R40&...y&_sacat=0
(02-20-2016, 04:26 PM)AUDIOTEK Wrote: So any of those will work?
They might work in theory but a) you'll need a lot more mAh than a couple of hundred, think more like 8000mAh for anything useful, and b) still not 100% sure of connector type.
Think more like this.
If you can't find a Lithium battery suitable for use with a Pine A64 then an alternate approach is a USB battery pack. One suggestion is an Allpowers 3.5A Portable 15000mAH Power Bank with a price of $24.99 at Amazon Canada.
hrh1818
Ah, I missed this one and sorry on late reply, the connector is 3 pin JST PH type female connector. Picture included.
Many thanks, TL. This will help people source appropriate batteries.
(02-28-2016, 04:27 AM)SkairkrohBule Wrote: Many thanks, TL. This will help people source appropriate batteries.
Hi
I've seen CANADA AMAZON, a battery that maybe you like ..
1200mAh 3.7V Li-Poly Battery with JST-PH cable
or keep looking ..
Hi
or keep looking ..
That's good, but won't last very long. You need to bump up the mAh Big Grin
Question Z-Wave module pinout to make it compatible with Pi b+ ebretteville 59 128,454 07-12-2019, 08:55 AM
Last Post: kris240376
  What cameras are compatible with that ribbon connector? nayrenitnatsnoc 1 6,175 02-18-2017, 11:50 PM
Last Post: dkryder
  Raspberry Pi and Arduino accessories compatible? Krowyn 6 16,054 10-08-2016, 10:36 AM
Last Post: rohan
  Lithium Polymer Battery USA / CERTAIN EUROPE COUNTRIES ONLY JulianM 11 25,396 09-07-2016, 04:40 PM
Last Post: Mednar
  General Battery Questions nspireing 11 24,951 07-03-2016, 03:15 AM
Last Post: pfeerick
Question lipo battery boot issue Luke 5 12,357 05-29-2016, 02:13 PM
Last Post: Luke
  RTC battery steve8939 2 7,095 05-25-2016, 04:58 PM
Last Post: steve8939
Question Camera / Lcd / Battery documentation soufyen 1 5,448 04-29-2016, 03:24 PM
Lightbulb What is the third battery pin for? combs 1 5,881 04-20-2016, 04:39 PM
Last Post: rahlquist
  Zwave AU compatible mist42nz 1 5,171 03-23-2016, 04:00 AM
Last Post: Ghost
