Pinephone Pro LTE issue
Bug
Hey pinefriends! This is my first post.
I got my Pinephone Pro Explorer Edition in the mail a couple days ago. I've installed Tow-Boot, Mobian Phosh, and the 0.6.8 firmware update for the modem. I did this via the 'firmware' app from the software center. Currently I have an AT&T SIM card in the phone but plan to switch to Google-Fi before long. Almost every time the screen turns off I completely loose LTE such that the mobile connection section of the settings app disappears. It also happens, much more rarely, in the middle of actively using the phone. It's happened while writing a text message, while browsing on firefox, and even just while scrolling through the apps section. It does not loose it's connection to WiFi when this happens, so I know it's not the whole modem shutting off. Before updating the EG25 firmware I had to reboot the phone each time this happened. Now it consistently reappears when I enter the network settings and start the process of creating a new wired connection.
  https://forum.pine64.org/showthread.php?tid=14342  --this thread gave me the idea to try systemctl edit --full ModemManager to change --test-quick-suspend-resume to --test-no-suspend-resume
I didn't see that line or anything like it in the file that was opened.
Please if anyone knows why this is happening or has advice on how to fix it that would be lovely. It's really the main thing standing between me and PPP as a daily driver.
Have you tried this:
Quote:
  1. Stop the modem from disappearing on suspend
  • Edit
    /usr/lib/udev/rules.d/80-modem-eg25.rules
  • Look at the last line:
    ACTION=="add", SUBSYSTEM=="usb", DRIVERS=="usb", ENV{DEVTYPE}=="usb_device", ATTRS{idVendor}=="2c7c", ATTRS{idProduct}=="0125", ATTR{power/persist}="0"
  • And change persist to 1:
    ACTION=="add", SUBSYSTEM=="usb", DRIVERS=="usb", ENV{DEVTYPE}=="usb_device", ATTRS{idVendor}=="2c7c", ATTRS{idProduct}=="0125", ATTR{power/persist}="1"
  • Edit
    /usr/share/eg25-manager/pine64,pinephone-pro.toml
    and make sure
    monitor_udev
    is set to
    false
The above is copied from
https://github.com/the-modem-distro/pine...ETTINGS.md
Actually latest eg25.rules has 4 goto statements in first 4 lines. Make sure line 3 is DEVICES (plural), not DEVICE. You shouldn´t need the other changes.
(09-07-2022, 12:07 PM)DoesOkay Wrote: I got my Pinephone Pro Explorer Edition...
So better then to post in Pinephone Pro section of this forum Smile
This is regular Pinephone section (not Pro) Big Grin
My experience with Manjaro PlaMo: https://forum.pine64.org/showthread.php?tid=15300
Okay I've just done that now. If the problem persists I'll be back to ask for more help. Thank you very much!
Oop! I didn't realize there were two sections, sorry!
  Pinephone visibly losing power while plugged in Hiraghm 10 9,599 10-14-2026, 04:20 PM
Last Post: Flymoon
  Pinephone software Csanderson0313 3 1,950 07-10-2026, 02:21 PM
  PinePhone Game Thread PixelPaintbrush 31 88,181 06-11-2026, 02:50 PM
Last Post: elinkser
  How can I record video on a Pinephone? kk22 23 26,629 03-25-2026, 12:55 PM
Last Post: baptx
  pinephone-support package not upgradable on Mobian fhireman 5 8,932 02-28-2026, 05:49 PM
Last Post: baptx
  beep - playing PCM samples on PinePhone? WhiteHexagon 0 1,759 12-04-2025, 08:07 AM
Last Post: WhiteHexagon
Star Selling my Pinephone Pro Explorer Edition zheyon 2 5,354 12-01-2025, 10:25 AM
  PinePhone sensors - Gyroscope power WhiteHexagon 3 3,024 11-30-2025, 08:07 AM
  Light Sensor / Proximity Sensor on PinePhone? WhiteHexagon 1 2,389 11-18-2025, 03:07 PM
  Pinephone boot. Richy_T 8 8,810 10-21-2025, 12:12 PM
Last Post: Richy_T
