Pine H64 antenna connector
I'd like to replace the antenna on the H64 with an RP-SMA pigtail for a larger antenna. Unfortunately I can't identify the SMD antenna connector. The schematic on the wiki page only refers to J21/ANT1 and there doesn't seem to be a BOM with a P/N.
https://forum.pine64.org/showthread.php?tid=5624&page=9 This thread refers to "uFL", but I bought a uFL pigtail and the pine's connector is definitely larger.
https://forum.pine64.org/showthread.php?tid=7569 According to this thread it's MHF4, but again MHF4 appears to be smaller than what I have. In this drawing (https://www.i-pex.com/sites/default/file...449C15.pdf) MHF4 receptables appear to have 1.5 mm mating diameter, the receptable on my H64 measures to 2.1 mm dia with calipers.
Anyone have an idea?
Didn't get an answer, so I went ahead and bought a cable with a MHF1 connector. It seems to work fine. Hope this is helpful to others, I'll also add the info to the wiki.
The connector is U.FL type, https://en.wikipedia.org/wiki/Hirose_U.FL
  Pine H64 rajsachdev 10 24,795 06-09-2023, 10:50 AM
Last Post: as365n4
  Pine H64 Stock ky56 0 3,660 10-26-2022, 04:37 PM
Last Post: ky56
Sad Pine A64 parts Miguelito71 0 4,002 01-18-2022, 02:24 PM
Last Post: Miguelito71
  PINE H64 Wiki page is up tllim 2 15,021 03-27-2019, 08:03 PM
Last Post: tuxd3v
  Pine H64 Model B OS images ameridroid 2 8,439 03-13-2019, 09:48 AM
Last Post: NicoD
  Pine H64 1Gb|2Gb "out of stock" sineloco 29 75,788 08-24-2018, 08:17 AM
Last Post: Arkadiusz
  PINE H64 u-boot and kernel shinymetal 2 9,218 02-28-2018, 02:05 PM
Last Post: shinymetal
