PINE H64 u-boot and kernel
Hi all,
any chance to have infos about building u-boot and kernel for H64?
I'm planning to buy one of this, but only if there are the sources for boot and kernel...
Regards
Hi, H6 support in mainline Linux/u-boot is very early in the dev cycle atm since boards are just arriving for community developers, and the new 4.9.x BSP from Allwinner is still in beta, I described which sources I use to run Arch on mainline here:
https://forum.pine64.org/showthread.php?...3#pid35873
(02-28-2018, 10:35 AM)xalius Wrote: Hi, H6 support in mainline Linux/u-boot is very early in the dev cycle atm since boards are just arriving for community developers, and the new 4.9.x BSP from Allwinner is still in beta, I described which sources I use to run Arch on mainline here:
Great, I will post there. Thank you
  Pine H64 rajsachdev 10 25,022 06-09-2023, 10:50 AM
Last Post: as365n4
  Pine H64 Stock ky56 0 3,707 10-26-2022, 04:37 PM
Last Post: ky56
  Pine H64 antenna connector auxym 2 6,874 03-10-2022, 02:14 PM
Sad Pine A64 parts Miguelito71 0 4,046 01-18-2022, 02:24 PM
Last Post: Miguelito71
  eMMC boot help SuburbanDad 15 36,392 07-02-2020, 04:12 AM
Last Post: as365n4
  PINE H64 Wiki page is up tllim 2 15,099 03-27-2019, 08:03 PM
Last Post: tuxd3v
  Pine H64 Model B OS images ameridroid 2 8,507 03-13-2019, 09:48 AM
Last Post: NicoD
  Pine H64 1Gb|2Gb "out of stock" sineloco 29 76,175 08-24-2018, 08:17 AM
Last Post: Arkadiusz
