Pine H64
Just bought a board (in India), have tried various images on pine site and different power supplies and SD cards the board always gets stuck on
U-Boot SPL 2022.04 (Mar 01 2023 - 00:14:33 +00000)
DRAM:
it never goes past DRAM:
the date after SPL changes with different images but it's stuck on DRAM:
once in a while it give this message once , restarts and gets stuck on DRAM again:
DRAM: This DRAM setup is currently not supported.
(04-03-2023, 01:21 AM)rajsachdev Wrote: Just bought a board (in India), have tried various images on pine site and different power supplies and SD cards the board always gets stuck on
DRAM:
strange message, please post the actual console text. Suspect may use wrong OS build, such as using H64 model -A build or model-B.
Thanks for your reply...
Am using Images from this page: https://wiki.pine64.org/wiki/PINE_H64, have tried : Armbian, Debian: Bullseye, Bookworm, LibreElec, FreeBSD etc distros, all stop at the same point. Following same procedure for making SD card i've used for RPi's, Orange Pi's etc. I think these are images for Model B.
Comparing pictures and from the silk print on PCB it's Pine H64 Model B for sure. (PINE_H64_MODEL_B 2018-12-12)
Also have connected usb serial to exp port and am getting only following text on power on :
DRAM:
Here is screenshot of the same:
https://drive.google.com/file/d/1f3R1u1r...share_link
Is this the console text you are referring to? or something else? if something else how do I capture it?
DRAM:
Tried NetBSD (NetBSD-9-aarch64--pine-h64.img) for first time and saw a different error, attached log, it after few resets it stopped at DRAM: again, attached console log
U-Boot SPL 2021.01 (Oct 05 2021 - 17:39:31 +0000)
DRAM:Error while initializing DRAM PHY!
resetting ...
resetting ...
It sure looks like defective hardware to me.
:wq
[ SRA accepts you ]
(04-07-2023, 03:51 PM)KC9UDX Wrote: It sure looks like defective hardware to me.
Thanks, have been trying to get it exchanged, but vendor has no knowledge and contacting manufacturer...
tllim is the manufacturer.   Big Grin
:wq
[ SRA accepts you ]
Tongue Big Grin   didn't realize this, then only he can solve my problem. @tllim help please :-)
Strange, no answer from @tllim , if manufacturer won't help then who will? Am stuck with a dud piece and neither the vendor nor the manufacturer owns up to a bad piece! and users have to suffer, lost 1/3rd of my salary on a bad piece. Shame.
The H64 is an odd one and never got the broader support some of the other boards got.
Only thing I seem to have running okay is dietpi which is just fine, I can install/compile apps, run regular headless linux stuff or a light GUI, and with the built in wifi I don't need ehternet. Thinking of dropping it in an enclosure for outdoor use since I may not be able to do some more exoti stuff (at 3GB, it's plenty for running lots of CLI linux apps)
it doesn't get happy
it doesn't get sad
it just runs programs
  Pine H64 Stock ky56 0 1,434 10-26-2022, 04:37 PM
Last Post: ky56
  Pine H64 antenna connector auxym 2 2,878 03-10-2022, 02:14 PM
Sad Pine A64 parts Miguelito71 0 1,439 01-18-2022, 02:24 PM
Last Post: Miguelito71
  PINE H64 Wiki page is up tllim 2 12,092 03-27-2019, 08:03 PM
Last Post: tuxd3v
  Pine H64 Model B OS images ameridroid 2 5,505 03-13-2019, 09:48 AM
Last Post: NicoD
  Pine H64 1Gb|2Gb "out of stock" sineloco 29 51,459 08-24-2018, 08:17 AM
Last Post: Arkadiusz
  PINE H64 u-boot and kernel shinymetal 2 6,057 02-28-2018, 02:05 PM
Last Post: shinymetal
