Manjaro SD card boot issue
(06-04-2020, 06:52 PM)Arwen Wrote: I too found that mrfixit's U-Boot seems to be the best. I moved from the default Debian to Manjaro and had problems with booting. Was almost ready to go back to the default Debian when someone suggested just going back to the default Debian's U-Boot. That seems to have solved all my known boot problems. I can boot Manjaro or Debian from the SD card.
Can you please explain in a noob friendly way, if I boot up from mrfixit's Debian release and flash the eMMC with DD I will be able to use Debian?
Or it just the U-Boot that needs to be updated? If so then how? Sorry, I am comfortable flashing stuff to SD cards since I have my PinePhone, but this is different and I don't want to mess up my PBP. Sad
Manjaro SD card boot issue - by aeastw - 05-29-2020, 02:38 AM
RE: Manjaro SD card boot issue - by cefre00 - 06-04-2020, 05:00 AM
RE: Manjaro SD card boot issue - by wdt - 06-04-2020, 11:02 AM
RE: Manjaro SD card boot issue - by aeastw - 06-04-2020, 03:27 PM
RE: Manjaro SD card boot issue - by Arwen - 06-04-2020, 06:52 PM
RE: Manjaro SD card boot issue - by cefre00 - 06-05-2020, 01:27 AM
RE: Manjaro SD card boot issue - by khanku - 06-05-2020, 03:47 AM
RE: Manjaro SD card boot issue - by cefre00 - 06-06-2020, 02:46 AM
RE: Manjaro SD card boot issue - by tophneal - 06-05-2020, 06:34 AM
  Manjaro Sway Theme Broken Eighty8 1 335 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,808 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 383 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,245 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,344 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 462 12-07-2023, 03:11 PM
  Boot Order in Pinebook Pro food 8 1,396 11-23-2023, 07:37 AM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 967 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,063 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 2,033 08-21-2023, 09:08 PM
