The RTL-SDR and the Pinebook Pro
I feel silly now: I tried building the rtl-sdr driver from source (using the AUR package) and it just worked right off the bat without a hitch. It's actually running better and dropping fewer samples than it does on my Thinkpad.
All I wonder now: what happened on the Manjaro ARM end of things to make it break so thoroughly in the binary release?
Anyway, if you happen to be running up against the same issue here (the RTL-SDR emitting a short loop of junk samples instead of real signals when run on the Pinebook Pro under Manjaro), try building the rtl-sdr-git package from the AUR. Given the silence in this thread, this isn't a particularly common issue, but I hope what I found eventually helps someone else.
Guess I should submit a bug report to the Manjaro maintainer?
The RTL-SDR and the Pinebook Pro - by diodelass - 05-27-2020, 07:04 PM
RE: The RTL-SDR and the Pinebook Pro - by diodelass - 05-30-2020, 09:45 AM
RE: The RTL-SDR and the Pinebook Pro - by tllim - 05-30-2020, 06:23 PM
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 4 758 05-06-2024, 09:27 AM
  Pinebook Pro on Debian 12 Power Issue u974615 1 380 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 325 02-17-2024, 07:06 PM
  Pinebook Pro charging issues tomekdev 1 663 01-05-2024, 08:40 PM
Last Post: tomekdev
  Replacement battery for PineBook Pro DrYak 3 1,172 11-07-2023, 10:09 AM
Last Post: DrYak
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 131,950 09-13-2023, 03:43 AM
Last Post: k3dAR
  PineBook Pro dead ottahe 9 6,153 01-18-2023, 07:41 PM
Last Post: ottahe
  Pinebook Pro malfunctioned hardware samtux 10 4,585 12-27-2022, 03:31 PM
Last Post: samtux
  PineBook Pro revision 2.2: Wishlist for the hardware issue fixes dsimic 115 138,362 11-30-2022, 04:28 PM
  Decent Pinebook Pro barrel PSU / Charger petaramesh 3 1,971 10-21-2022, 07:57 AM
Last Post: dachalife
