screen doesn't turn on atll
Hi, my pinebook pro recently stopped working.
Symptoms:
1. when https://forum.pine64.org/member.phpbooting from built in memory, power led lights red and thats all - there is no image on the display (display does not turn on at all)
2. when booting from sd card with manjaro, pinebook turns on, power led starts red, but after some time turns green. Then i can toggle num lock/caps lock leds (works with both internal and external keyboard), but still - display is not enabled.
I've tried starting pinebook using either original adapter or usb c power adapter or with no external power - no luck.
Additionally I've tried to turn on pinebook with all internal plugs disconnected (excluding display and keyboard), but this changed nothing.
Before the notebook stopped working I've replaced default, old manjaro repositories with new and started update. The update failed to updated some things (cant remember which, but I don't remember it being anything important/system related). I can't remember exactly- I think after the update i managed to reboot the netbook, but something was not working so I decided to make clean install using SD card. I mange to boot into GUI from SD card, copy files from  /home to NVMe drive. Then i flashed manjaro installer onto sd card and installed the OS. It finished, but i couldn't boot OS (there were some glitches). I switched  sd cards (the same model) and repeated process with the second card.
At some point the display stopped turning on.
I have soldered myself audio->uart adapter, switched internal uart switch, but i got no luck seeing any messages on the debug console (maybe i have to do something to enable debug output?)
Is there anything i can do to debug/repair the problem?
Thanks in advance for your help ;]
screen doesn't turn on atll - by mroz - 05-24-2020, 02:50 PM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 299 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,230 12-15-2023, 02:11 PM
  Black screen by start up bluedemon382 10 2,971 07-27-2023, 07:49 AM
Last Post: dstallmo
  PBP blank screen after updating Manjaro Franko 6 2,023 04-01-2023, 07:55 AM
Last Post: hacknix
  Doesn’t power on after flashing emmc badguru 3 1,261 02-25-2023, 09:00 PM
Last Post: badguru
  Pinebook Pro won't turn on after flashing image Idaho 2 1,106 02-21-2023, 02:31 PM
Last Post: Idaho
Question Pinebook Pro shows only bright white screen when powered on Sean Whitton 3 2,001 07-22-2022, 01:19 PM
  Ring around screen following update tylerjohnson3208 2 2,100 05-10-2022, 01:52 AM
Last Post: diyagabriel
  Looking for Screen LCD Panel for the Pinebook Pro gerstavros 3 2,750 05-09-2022, 05:53 AM
Last Post: gerstavros
  Pinebook Pro not turn carbo29 11 6,540 03-12-2022, 12:42 PM
Last Post: carbo29
