Manjaro ARM 20.04
#64
Thank you for sharing your experience with Armbian. I decide to fix my operating system of choice as Manjaro Sway edition. It has the least of the problems among others: my bluetooth headset not working and some of the terminal based programs, eg neovim, R etc, are not launching from Wofi. Otherwise everything is good including Chromium Widevine...
I will keep an eye on fedora XFCE and I will test it when 33 is released. I think Fedora has been the second least problematic linux os after Manjaro Sway: sometimes fedora doesn't boot from micro sd and I end up booting to default manjaro kde on the flash emmc, also the sound interface problem. Bluetooth and wifi are working perfectly with Fedora XFCE as of now.
I guess I can learn about Manjaro and Sway wm in the meantime. If I could fix the Manjaro sway problems, I am good with using sway as my main productivity environment.
I am sorry that Manjaro XFCE doesn't work well. I am very disappointed with Manjaro KDE. Manjaro Sway works much better on my Pinebook Pro.
Manjaro ARM 20.04 - by spikerguy - 05-21-2020, 04:55 PM
RE: Manjaro ARM 20.04 - by TDC_PBP - 05-27-2020, 03:41 PM
RE: Manjaro ARM 20.04 - by xmixahlx - 05-27-2020, 07:52 PM
RE: Manjaro ARM 20.04 - by mstrstvns - 05-28-2020, 11:24 AM
RE: Manjaro ARM 20.04 - by spikerguy - 05-28-2020, 02:17 PM
RE: Manjaro ARM 20.04 - by Der Geist der Maschine - 05-29-2020, 12:04 AM
RE: Manjaro ARM 20.04 - by pfeerick - 06-01-2020, 05:48 AM
RE: Manjaro ARM 20.04 - by cefre00 - 06-04-2020, 08:59 AM
RE: Manjaro ARM 20.04 - by tiagoespinha - 06-06-2020, 11:06 AM
RE: Manjaro ARM 20.04 - by tiagoespinha - 06-06-2020, 02:09 PM
RE: Manjaro ARM 20.04 - by spikerguy - 06-07-2020, 07:48 AM
RE: Manjaro ARM 20.04 - by zaius - 06-07-2020, 03:53 PM
RE: Manjaro ARM 20.04 - by spikerguy - 06-09-2020, 06:14 AM
RE: Manjaro ARM 20.04 - by User 18041 - 06-10-2020, 11:01 AM
RE: Manjaro ARM 20.04 - by spikerguy - 06-11-2020, 06:00 AM
RE: Manjaro ARM 20.04 - by User 18041 - 06-11-2020, 01:50 PM
RE: Manjaro ARM 20.04 - by q4osteam - 06-12-2020, 02:07 AM
RE: Manjaro ARM 20.04 - by spikerguy - 06-13-2020, 04:53 AM
RE: Manjaro ARM 20.04 - by Redbeard - 08-10-2020, 03:37 PM
RE: Manjaro ARM 20.04 - by linuxfreund - 06-12-2020, 03:41 PM
RE: Manjaro ARM 20.04 - by q4osteam - 06-16-2020, 09:02 AM
RE: Manjaro ARM 20.04 - by jiyong - 06-16-2020, 01:32 PM
RE: Manjaro ARM 20.04 - by PRStoetzer - 06-16-2020, 08:31 PM
RE: Manjaro ARM 20.04 - by spikerguy - 06-17-2020, 03:43 AM
RE: Manjaro ARM 20.04 - by ovv - 06-17-2020, 03:58 AM
RE: Manjaro ARM 20.04 - by PRStoetzer - 06-18-2020, 01:59 PM
Screen Brightness - by theplaidtieninja - 06-19-2020, 09:05 AM
RE: Screen Brightness - by spikerguy - 06-19-2020, 03:55 PM
RE: Screen Brightness - by theplaidtieninja - 06-19-2020, 06:59 PM
RE: Screen Brightness - by greysuite - 06-23-2020, 08:59 PM
RE: Manjaro ARM 20.04 - by anoctis - 06-19-2020, 05:56 PM
RE: Manjaro ARM 20.04 - by anoctis - 06-20-2020, 03:50 PM
RE: Manjaro ARM 20.04 - by User 6582 - 06-23-2020, 09:12 AM
RE: Manjaro ARM 20.04 - by jiapei100 - 06-28-2020, 12:53 AM
RE: Manjaro ARM 20.04 - by S265 - 06-28-2020, 04:53 AM
RE: Manjaro ARM 20.04 - by spikerguy - 06-29-2020, 02:44 AM
RE: Manjaro ARM 20.04 - by S265 - 06-29-2020, 03:48 PM
RE: Manjaro ARM 20.04 - by wdt - 07-22-2020, 03:54 PM
RE: Manjaro ARM 20.04 - by thepeckhambassplayer - 07-25-2020, 04:36 PM
RE: Manjaro ARM 20.04 - by wdt - 07-25-2020, 07:48 PM
RE: Manjaro ARM 20.04 - by thepeckhambassplayer - 08-01-2020, 11:04 AM
RE: Manjaro ARM 20.04 - by Redbeard - 08-12-2020, 08:42 AM
RE: Manjaro ARM 20.04 - by carlosqueso - 08-12-2020, 01:35 PM
RE: Manjaro ARM 20.04 - by Redbeard - 08-12-2020, 04:10 PM
RE: Manjaro ARM 20.04 - by carlosqueso - 08-12-2020, 06:47 PM
RE: Manjaro ARM 20.04 - by 8jef - 08-19-2020, 09:08 PM
RE: Manjaro ARM 20.04 - by spikerguy - 08-20-2020, 03:17 PM
RE: Manjaro ARM 20.04 - by 8jef - 08-20-2020, 04:56 PM
RE: Manjaro ARM 20.04 - by cefre00 - 08-25-2020, 05:37 AM
RE: Manjaro ARM 20.04 - by nightranger73 - 09-17-2020, 08:37 AM
RE: Manjaro ARM 20.04 - by carlosqueso - 09-24-2020, 07:28 PM
RE: Manjaro ARM 20.04 - by poVoq - 09-23-2020, 04:59 PM
RE: Manjaro ARM 20.04 - by pine76 - 09-29-2020, 04:09 PM
RE: Manjaro ARM 20.04 - by wdt - 09-29-2020, 05:51 PM
RE: Manjaro ARM 20.04 - by pine76 - 10-04-2020, 12:00 PM
RE: Manjaro ARM 20.04 - by wdt - 10-04-2020, 04:12 PM
RE: Manjaro ARM 20.04 - by pine76 - 10-04-2020, 10:59 PM
RE: Manjaro ARM 20.04 - by wdt - 10-04-2020, 11:15 PM
RE: Manjaro ARM 20.04 - by pine76 - 10-05-2020, 07:45 AM
RE: Manjaro ARM 20.04 - by wdt - 10-05-2020, 12:57 PM
RE: Manjaro ARM 20.04 - by pine76 - 10-06-2020, 09:23 PM
RE: Manjaro ARM 20.04 - by rempfer - 10-16-2020, 01:30 AM
RE: Manjaro ARM 20.04 - by markifi - 02-23-2021, 03:22 PM
RE: Manjaro ARM 20.04 - by vandys - 12-27-2022, 08:11 PM
RE: Manjaro ARM 20.04 - by Yochanan - 12-28-2022, 02:53 PM
RE: Manjaro ARM 20.04 - by vandys - 01-08-2023, 07:22 PM
  Manjaro Sway Theme Broken Eighty8 1 334 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,806 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 382 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,244 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,341 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 458 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 967 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,061 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 2,030 08-21-2023, 09:08 PM
  Manjaro - HIbernate - brcmfmac clk issue pompeyPinePro 1 805 08-18-2023, 02:06 AM
Last Post: juliamenendez
