Manjaro ARM 20.04
#25
(06-17-2020, 03:43 AM)spikerguy Wrote:
(06-16-2020, 08:31 PM)PRStoetzer Wrote: Is there any way to get S3 suspend working on the latest Manjaro? That's really the only thing holding it back from being perfect at the moment (other than needing to downgrade the wifi firmware package).
Yes you will have to flash bsp uboot and then the S3 suspend will work fine.
Install the package using this command and then follow the instruction.
sudo pacman -S uboot-pinebookpro-bsp
Do not do this if you don't have experience with uboot or basic dd linux commands.
For whatever reason this does not work on my first run 64 GB ISO Pinebook Pro. It no longer boots to the EMMC, but it will boot to SD. I reflashed the EMMC and tried again, but got the same results. I'll just stick to S2 for now, but I'd really like to be able to close the lid and leave it for a few hours or overnight without the battery draining.
Manjaro ARM 20.04 - by spikerguy - 05-21-2020, 04:55 PM
RE: Manjaro ARM 20.04 - by TDC_PBP - 05-27-2020, 03:41 PM
RE: Manjaro ARM 20.04 - by xmixahlx - 05-27-2020, 07:52 PM
RE: Manjaro ARM 20.04 - by mstrstvns - 05-28-2020, 11:24 AM
RE: Manjaro ARM 20.04 - by spikerguy - 05-28-2020, 02:17 PM
RE: Manjaro ARM 20.04 - by Der Geist der Maschine - 05-29-2020, 12:04 AM
RE: Manjaro ARM 20.04 - by pfeerick - 06-01-2020, 05:48 AM
RE: Manjaro ARM 20.04 - by cefre00 - 06-04-2020, 08:59 AM
RE: Manjaro ARM 20.04 - by tiagoespinha - 06-06-2020, 11:06 AM
RE: Manjaro ARM 20.04 - by tiagoespinha - 06-06-2020, 02:09 PM
RE: Manjaro ARM 20.04 - by spikerguy - 06-07-2020, 07:48 AM
RE: Manjaro ARM 20.04 - by zaius - 06-07-2020, 03:53 PM
RE: Manjaro ARM 20.04 - by spikerguy - 06-09-2020, 06:14 AM
RE: Manjaro ARM 20.04 - by User 18041 - 06-10-2020, 11:01 AM
RE: Manjaro ARM 20.04 - by spikerguy - 06-11-2020, 06:00 AM
RE: Manjaro ARM 20.04 - by User 18041 - 06-11-2020, 01:50 PM
RE: Manjaro ARM 20.04 - by q4osteam - 06-12-2020, 02:07 AM
RE: Manjaro ARM 20.04 - by spikerguy - 06-13-2020, 04:53 AM
RE: Manjaro ARM 20.04 - by Redbeard - 08-10-2020, 03:37 PM
RE: Manjaro ARM 20.04 - by linuxfreund - 06-12-2020, 03:41 PM
RE: Manjaro ARM 20.04 - by q4osteam - 06-16-2020, 09:02 AM
RE: Manjaro ARM 20.04 - by jiyong - 06-16-2020, 01:32 PM
RE: Manjaro ARM 20.04 - by PRStoetzer - 06-16-2020, 08:31 PM
RE: Manjaro ARM 20.04 - by spikerguy - 06-17-2020, 03:43 AM
RE: Manjaro ARM 20.04 - by ovv - 06-17-2020, 03:58 AM
RE: Manjaro ARM 20.04 - by PRStoetzer - 06-18-2020, 01:59 PM
Screen Brightness - by theplaidtieninja - 06-19-2020, 09:05 AM
RE: Screen Brightness - by spikerguy - 06-19-2020, 03:55 PM
RE: Screen Brightness - by theplaidtieninja - 06-19-2020, 06:59 PM
RE: Screen Brightness - by greysuite - 06-23-2020, 08:59 PM
RE: Manjaro ARM 20.04 - by anoctis - 06-19-2020, 05:56 PM
RE: Manjaro ARM 20.04 - by anoctis - 06-20-2020, 03:50 PM
RE: Manjaro ARM 20.04 - by User 6582 - 06-23-2020, 09:12 AM
RE: Manjaro ARM 20.04 - by jiapei100 - 06-28-2020, 12:53 AM
RE: Manjaro ARM 20.04 - by S265 - 06-28-2020, 04:53 AM
RE: Manjaro ARM 20.04 - by spikerguy - 06-29-2020, 02:44 AM
RE: Manjaro ARM 20.04 - by S265 - 06-29-2020, 03:48 PM
RE: Manjaro ARM 20.04 - by wdt - 07-22-2020, 03:54 PM
RE: Manjaro ARM 20.04 - by thepeckhambassplayer - 07-25-2020, 04:36 PM
RE: Manjaro ARM 20.04 - by wdt - 07-25-2020, 07:48 PM
RE: Manjaro ARM 20.04 - by thepeckhambassplayer - 08-01-2020, 11:04 AM
RE: Manjaro ARM 20.04 - by Redbeard - 08-12-2020, 08:42 AM
RE: Manjaro ARM 20.04 - by carlosqueso - 08-12-2020, 01:35 PM
RE: Manjaro ARM 20.04 - by Redbeard - 08-12-2020, 04:10 PM
RE: Manjaro ARM 20.04 - by carlosqueso - 08-12-2020, 06:47 PM
RE: Manjaro ARM 20.04 - by 8jef - 08-19-2020, 09:08 PM
RE: Manjaro ARM 20.04 - by spikerguy - 08-20-2020, 03:17 PM
RE: Manjaro ARM 20.04 - by 8jef - 08-20-2020, 04:56 PM
RE: Manjaro ARM 20.04 - by cefre00 - 08-25-2020, 05:37 AM
RE: Manjaro ARM 20.04 - by nightranger73 - 09-17-2020, 08:37 AM
RE: Manjaro ARM 20.04 - by carlosqueso - 09-24-2020, 07:28 PM
RE: Manjaro ARM 20.04 - by poVoq - 09-23-2020, 04:59 PM
RE: Manjaro ARM 20.04 - by pine76 - 09-29-2020, 04:09 PM
RE: Manjaro ARM 20.04 - by wdt - 09-29-2020, 05:51 PM
RE: Manjaro ARM 20.04 - by pine76 - 10-04-2020, 12:00 PM
RE: Manjaro ARM 20.04 - by wdt - 10-04-2020, 04:12 PM
RE: Manjaro ARM 20.04 - by pine76 - 10-04-2020, 10:59 PM
RE: Manjaro ARM 20.04 - by wdt - 10-04-2020, 11:15 PM
RE: Manjaro ARM 20.04 - by pine76 - 10-05-2020, 07:45 AM
RE: Manjaro ARM 20.04 - by wdt - 10-05-2020, 12:57 PM
RE: Manjaro ARM 20.04 - by pine76 - 10-06-2020, 09:23 PM
RE: Manjaro ARM 20.04 - by rempfer - 10-16-2020, 01:30 AM
RE: Manjaro ARM 20.04 - by markifi - 02-23-2021, 03:22 PM
RE: Manjaro ARM 20.04 - by vandys - 12-27-2022, 08:11 PM
RE: Manjaro ARM 20.04 - by Yochanan - 12-28-2022, 02:53 PM
RE: Manjaro ARM 20.04 - by vandys - 01-08-2023, 07:22 PM
  Manjaro Sway Theme Broken Eighty8 1 415 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,857 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 463 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,345 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,474 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 522 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 1,058 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,093 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 2,073 08-21-2023, 09:08 PM
  Manjaro - HIbernate - brcmfmac clk issue pompeyPinePro 1 873 08-18-2023, 02:06 AM
Last Post: juliamenendez
