Manjaro ARM 20.04
@spikerguy apologies if this is the wrong place to ask, but I've just had to reflash my PBP and went with the latest 20.04 - however I feel like the experience is slightly sluggish compared to the original image that came flashed out of the box (I didn't check what it was but I imagine it was 19.xx).
Do you have any clues as to why that may be? It's probably some config or missing piece of software, but I can't for the life of me figure out what that is.
I did notice other differences of 20.04 vs whatever was out of the box. For example with 20.04 we seem to default to libinput as the touchpad driver, where I'm sure out of the box the synaptics driver was installed.
On a more random and bizarre note... right after flashing I was able to connect to my 5Ghz network, but after installing all the updates I'm not able to connect to that network ever again. I can connect to the 2.4Ghz, but never again to 5Ghz. I even tried deleting the NetworkManager profile and configure it again but no luck. Any ideas?
Many thanks in advance! Thanks for all the great work and effort in general too Smile much appreciated!
Edit: I should mention the slugginess seems to be GPU-related. With 20.04 I can't watch videos on 1080p on Youtube where I was able to out of the box. Right now it just stutters along.
Manjaro ARM 20.04 - by spikerguy - 05-21-2020, 04:55 PM
RE: Manjaro ARM 20.04 - by TDC_PBP - 05-27-2020, 03:41 PM
RE: Manjaro ARM 20.04 - by xmixahlx - 05-27-2020, 07:52 PM
RE: Manjaro ARM 20.04 - by mstrstvns - 05-28-2020, 11:24 AM
RE: Manjaro ARM 20.04 - by spikerguy - 05-28-2020, 02:17 PM
RE: Manjaro ARM 20.04 - by Der Geist der Maschine - 05-29-2020, 12:04 AM
RE: Manjaro ARM 20.04 - by pfeerick - 06-01-2020, 05:48 AM
RE: Manjaro ARM 20.04 - by cefre00 - 06-04-2020, 08:59 AM
RE: Manjaro ARM 20.04 - by tiagoespinha - 06-06-2020, 11:06 AM
RE: Manjaro ARM 20.04 - by tiagoespinha - 06-06-2020, 02:09 PM
RE: Manjaro ARM 20.04 - by spikerguy - 06-07-2020, 07:48 AM
RE: Manjaro ARM 20.04 - by zaius - 06-07-2020, 03:53 PM
RE: Manjaro ARM 20.04 - by spikerguy - 06-09-2020, 06:14 AM
RE: Manjaro ARM 20.04 - by User 18041 - 06-10-2020, 11:01 AM
RE: Manjaro ARM 20.04 - by spikerguy - 06-11-2020, 06:00 AM
RE: Manjaro ARM 20.04 - by User 18041 - 06-11-2020, 01:50 PM
RE: Manjaro ARM 20.04 - by q4osteam - 06-12-2020, 02:07 AM
RE: Manjaro ARM 20.04 - by spikerguy - 06-13-2020, 04:53 AM
RE: Manjaro ARM 20.04 - by Redbeard - 08-10-2020, 03:37 PM
RE: Manjaro ARM 20.04 - by linuxfreund - 06-12-2020, 03:41 PM
RE: Manjaro ARM 20.04 - by q4osteam - 06-16-2020, 09:02 AM
RE: Manjaro ARM 20.04 - by jiyong - 06-16-2020, 01:32 PM
RE: Manjaro ARM 20.04 - by PRStoetzer - 06-16-2020, 08:31 PM
RE: Manjaro ARM 20.04 - by spikerguy - 06-17-2020, 03:43 AM
RE: Manjaro ARM 20.04 - by ovv - 06-17-2020, 03:58 AM
RE: Manjaro ARM 20.04 - by PRStoetzer - 06-18-2020, 01:59 PM
Screen Brightness - by theplaidtieninja - 06-19-2020, 09:05 AM
RE: Screen Brightness - by spikerguy - 06-19-2020, 03:55 PM
RE: Screen Brightness - by theplaidtieninja - 06-19-2020, 06:59 PM
RE: Screen Brightness - by greysuite - 06-23-2020, 08:59 PM
RE: Manjaro ARM 20.04 - by anoctis - 06-19-2020, 05:56 PM
RE: Manjaro ARM 20.04 - by anoctis - 06-20-2020, 03:50 PM
RE: Manjaro ARM 20.04 - by User 6582 - 06-23-2020, 09:12 AM
RE: Manjaro ARM 20.04 - by jiapei100 - 06-28-2020, 12:53 AM
RE: Manjaro ARM 20.04 - by S265 - 06-28-2020, 04:53 AM
RE: Manjaro ARM 20.04 - by spikerguy - 06-29-2020, 02:44 AM
RE: Manjaro ARM 20.04 - by S265 - 06-29-2020, 03:48 PM
RE: Manjaro ARM 20.04 - by wdt - 07-22-2020, 03:54 PM
RE: Manjaro ARM 20.04 - by thepeckhambassplayer - 07-25-2020, 04:36 PM
RE: Manjaro ARM 20.04 - by wdt - 07-25-2020, 07:48 PM
RE: Manjaro ARM 20.04 - by thepeckhambassplayer - 08-01-2020, 11:04 AM
RE: Manjaro ARM 20.04 - by Redbeard - 08-12-2020, 08:42 AM
RE: Manjaro ARM 20.04 - by carlosqueso - 08-12-2020, 01:35 PM
RE: Manjaro ARM 20.04 - by Redbeard - 08-12-2020, 04:10 PM
RE: Manjaro ARM 20.04 - by carlosqueso - 08-12-2020, 06:47 PM
RE: Manjaro ARM 20.04 - by 8jef - 08-19-2020, 09:08 PM
RE: Manjaro ARM 20.04 - by spikerguy - 08-20-2020, 03:17 PM
RE: Manjaro ARM 20.04 - by 8jef - 08-20-2020, 04:56 PM
RE: Manjaro ARM 20.04 - by cefre00 - 08-25-2020, 05:37 AM
RE: Manjaro ARM 20.04 - by nightranger73 - 09-17-2020, 08:37 AM
RE: Manjaro ARM 20.04 - by carlosqueso - 09-24-2020, 07:28 PM
RE: Manjaro ARM 20.04 - by poVoq - 09-23-2020, 04:59 PM
RE: Manjaro ARM 20.04 - by pine76 - 09-29-2020, 04:09 PM
RE: Manjaro ARM 20.04 - by wdt - 09-29-2020, 05:51 PM
RE: Manjaro ARM 20.04 - by pine76 - 10-04-2020, 12:00 PM
RE: Manjaro ARM 20.04 - by wdt - 10-04-2020, 04:12 PM
RE: Manjaro ARM 20.04 - by pine76 - 10-04-2020, 10:59 PM
RE: Manjaro ARM 20.04 - by wdt - 10-04-2020, 11:15 PM
RE: Manjaro ARM 20.04 - by pine76 - 10-05-2020, 07:45 AM
RE: Manjaro ARM 20.04 - by wdt - 10-05-2020, 12:57 PM
RE: Manjaro ARM 20.04 - by pine76 - 10-06-2020, 09:23 PM
RE: Manjaro ARM 20.04 - by rempfer - 10-16-2020, 01:30 AM
RE: Manjaro ARM 20.04 - by markifi - 02-23-2021, 03:22 PM
RE: Manjaro ARM 20.04 - by vandys - 12-27-2022, 08:11 PM
RE: Manjaro ARM 20.04 - by Yochanan - 12-28-2022, 02:53 PM
RE: Manjaro ARM 20.04 - by vandys - 01-08-2023, 07:22 PM
  Manjaro Sway Theme Broken Eighty8 1 340 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,811 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 388 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,256 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,364 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 465 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 971 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,068 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 2,037 08-21-2023, 09:08 PM
  Manjaro - HIbernate - brcmfmac clk issue pompeyPinePro 1 812 08-18-2023, 02:06 AM
Last Post: juliamenendez
