Manjaro 20.03 did not update.
(05-14-2020, 10:31 AM)MrDitchy Wrote: I installed Manjaro KDE onto my eMMC from the SD card using the DD method. Almost straight away I was notified that updates were available via the desktop icon, I updated and all was good. I then used my Pinebook Pro as normal, however I did not see the update icon offer any updates, so I would open the software updater and check only to be told that my system was up to date.
I saw that version 20.04 was available. I checked and found out that I was on version 20.03, so I ran the software update and it told me that my machine was up to date. I then dowloaded (via anotherPC) and reinstalled Manjaro, this time version 20.04 and again was informed via the update icon that there were updates available. I got an error telling me that one of the updates could not dowload as a file already existed, solved by renaming the file and running the update again.
So I am now running Manjaro KDE 20.04 but my question is how come 20.03 did not update?  Huh
Thanks in advance Smile
Not sure if your problem is the same as mine. But I also had trouble updating my pinebook pro -- also using Manjaro KDE.
For me it was two things.
1. Apparently they moved the mirrors and that is why from the update icon I only got "there are no updates available" while `pacman` told me that it could not reach anything. (source)
2. After 1. was fixed, I still had some trouble updating. It told me something about an nss file already existing. That had something to do with arch and I followed this
[url=https://www.archlinux.org/news/nss3511-1-and-lib32-nss3511-1-updates-require-manual-intervention/][/url]
Manjaro 20.03 did not update. - by MrDitchy - 05-14-2020, 10:31 AM
RE: Manjaro 20.03 did not update. - by User 15552 - 05-18-2020, 01:17 PM
RE: Manjaro 20.03 did not update. - by User 15552 - 05-19-2020, 11:37 AM
  Manjaro Sway Theme Broken Eighty8 1 334 03-08-2024, 08:41 AM
Exclamation 'failed to open panfrost' after system update using archarm Puckla 1 379 03-01-2024, 06:46 PM
Last Post: Puckla
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,806 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 382 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,244 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,342 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 458 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 967 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,061 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 2,030 08-21-2023, 09:08 PM
