Audio 3.5mm Jack not working
(05-23-2020, 02:26 AM)clement Wrote: Hi,
Sorry for the late answer, I didn't get notification by email.
# amixer set 'Right Headphone Mixer Right DAC' on
amixer: Unable to find simple control 'Right Headphone Mixer Right DAC',0
I have no idea how to adjust parameters.
If I understood properly, I can use
# amixer scontrols
# amixer scontents
to list the devices, but it doesn't return anything.
# amixer info
Card default 'HDMI'/'HDMI'
 Mixer name : ''
 Components : ''
 Controls      : 3
 Simple ctrls  : 0
for me, amixer returns :
Card default 'rockchiprk3399'/'rockchip,rk3399'
 Mixer name : ''
 Components : ''
 Controls      : 35
 Simple ctrls  : 35
It seems that you are using hdmi output, therefore you have to switch the card.
You can probably use alsamixer command or
amixer -c 0 set Headphone playback 100% unmute
0 should be rockship sound card
Audio 3.5mm Jack not working - by clement - 05-05-2020, 03:09 PM
RE: Audio 3.5mm Jack not working - by LMM - 05-17-2020, 03:57 PM
RE: Audio 3.5mm Jack not working - by clement - 05-23-2020, 02:26 AM
RE: Audio 3.5mm Jack not working - by LMM - 05-23-2020, 04:11 PM
RE: Audio 3.5mm Jack not working - by clement - 05-24-2020, 01:25 AM
RE: Audio 3.5mm Jack not working - by LMM - 05-24-2020, 02:02 AM
RE: Audio 3.5mm Jack not working - by clement - 05-24-2020, 02:23 AM
RE: Audio 3.5mm Jack not working - by LMM - 05-24-2020, 02:54 AM
RE: Audio 3.5mm Jack not working - by clement - 05-24-2020, 03:05 AM
RE: Audio 3.5mm Jack not working - by clement - 05-24-2020, 09:38 AM
  power button not working Vista8720 0 61 05-07-2024, 11:26 PM
Last Post: Vista8720
  Cant get rockpro64 working brasilikum 3 1,887 03-19-2023, 06:22 AM
Last Post: runyor
  RockPro64 Stopped working WarpLover 5 2,735 02-06-2023, 10:10 AM
Last Post: diizzy
  After Power Loss feature working bdherouville 2 2,282 08-22-2022, 03:52 AM
Last Post: bdherouville
Music No success with audio crmcalls 2 3,184 04-15-2021, 11:17 PM
Last Post: crmcalls
  No sound from rockpro64 audio jack. rahulsharma 2 4,513 11-18-2020, 04:46 AM
Last Post: Wizzard
  When did the wifi module start working? stormchaser3000 1 3,110 11-12-2020, 08:59 AM
Last Post: Darren
  micro SD Card Slot Spring not working, Cant boot mjembd 1 3,164 04-16-2020, 12:30 AM
Last Post: mjembd
  board not working kardanadm 7 9,270 08-31-2019, 07:37 AM
Last Post: kardanadm
  board not working with EMMC RockPro64Newbie 1 2,952 05-10-2019, 02:22 AM
Last Post: Unkn0wn
