board not working
Hi
When I woke up one morning, I wanted to turn on rockpro64, but it didn't. Green LED flickers, white and red LEDs do not light. board not working. What could be the problem?
"RockPro64 4GB"
(07-03-2019, 07:17 AM)kardanadm Wrote: Hi
"RockPro64 4GB"
The green led shouldn't flicker, what power supply are you using?
"RockPro64 4GB"
I used two different 12V power supplies.
12V 4.5A and 12V 3.3A
"RockPro64 4GB"
board is still not working. Should I throw it in the trash or repair it? What is your advice? where the problem may be. I want to take it to an electrician for repair. Is there any possibility of repair?
"RockPro64 4GB"
According to the wiki, the green LED should light as long as there is 12V applied to the connector. (Even if the RockPro64 is powered off.)
I have no clue on what is your issue, and I dont have such devices yet, but if I were you I would start by looking at the card, and check if there is some burned electronic component.
By the way, after how much time did you get this issue ? Are you using your device a lot ?
"RockPro64 4GB"
I wasn't home. my wife and children watched movies on youtube. Maybe they didn't shut down SBC, they don't remember. I came home in the morning and wanted to run SBC, it did not work.
I got this SBC from Ameridroid. previously bought another rockpro64 and odroid-n2, malfunctioned and implemented RMA. Thank you very much to Ameridroid.
We communicated for this board, they asked me to send the board to them, and I sent the board to them.
The board went to the US but they did not look at the board, did not detect problems. The board returned it back to me, they told you I've done a lot RMA. They may be right.
Cargo from Turkey usa 20 dollars and 30 dollars I paid taxes, RMA to return. I'm angry and sorry for that.
I asked them to tell me what's wrong with the Bboard, they cut off the communication.
I dont understand.
You said that Amerdroid "did not look at the board, did not detect problems". How can they tell you your board has no issue if they didnt look at it ?
And you had several issue, on different kind of boards ? So maybe all your boards are ok but your electrical power supply (if you use one) isn't ok ?
And you paid 20 USD + 30  USD= 50 USD only for RMA ? At this price I would have preferred to buy a new board ...
(08-31-2019, 06:23 AM)kaylios Wrote: I dont understand.
They didn't check the board. board is broken or board is not broken, they did not tell me. they just sent it back Smile
I have two different PSUs and now I'm using this PSU for odroid-n2. no problem on the PSU.
Yes I've paid 50 USD, maybe more Smile
Ameridroid told me you wanted to do RMA. asked me to return the board. board US went. then he realized and thought that he did me a lot RMA  Big Grin
I am sorry for my English. I am writing with google translate.
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 674 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 627 08-14-2023, 07:55 AM
Last Post: kundanjha
  Cant get rockpro64 working brasilikum 3 1,703 03-19-2023, 06:22 AM
Last Post: runyor
  RockPro64 Stopped working WarpLover 5 2,522 02-06-2023, 10:10 AM
Last Post: diizzy
  Cannot get my board to boot deutschlmao 11 7,840 09-05-2022, 04:23 PM
Last Post: ljones
  After Power Loss feature working bdherouville 2 2,122 08-22-2022, 03:52 AM
Last Post: bdherouville
  Never ever mix up CPU board connector with 8-pin PCIE connector LMM 0 1,731 02-11-2021, 10:18 AM
Last Post: LMM
  When did the wifi module start working? stormchaser3000 1 3,007 11-12-2020, 08:59 AM
Last Post: Darren
  RockPro64 SSD Expansion Board/SATA Shield as0zial 5 7,487 10-18-2020, 08:05 PM
Last Post: revoman
  Audio 3.5mm Jack not working clement 9 11,668 05-24-2020, 09:38 AM
Last Post: clement
