Chromium GPU support on Manjaro
(04-20-2020, 06:40 AM)maxjrh Wrote: Binaries called "chrome" or "chromium" are explicitly blacklisted by the panfrost driver.
Is that the reason caidao works?
(04-19-2020, 06:39 AM)krist Wrote: (Note that apart from Chromium, hw decoding works just fine for me in Manjaro using mpv for example.)
I don't really believe that, especially the "just fine" part. I would really like to know which libraries you compiled and with which flags.
What does mpv say when you push Ctrl+h during a video?
Of course you're right, I mixed up GPU/VPU. mpv does NOT use hw-accel. video decoding, but it does use the GPU Renderer via Panfrost:
[vo/gpu/opengl] EGL_VERSION=1.4
[vo/gpu/opengl] EGL_VENDOR=Mesa Project
[vo/gpu/opengl] EGL_CLIENT_APIS=OpenGL OpenGL_ES
[vo/gpu/opengl] Trying to create Desktop OpenGL context.
[vo/gpu/opengl] Choosing visual EGL config 0x5, visual ID 0x21
[vo/gpu/opengl] GL_VERSION='2.1 Mesa 20.1.0-devel (git-ff8daa0136)'
[vo/gpu/opengl] Detected desktop OpenGL 2.1.
[vo/gpu/opengl] GL_VENDOR='Panfrost'
[vo/gpu/opengl] GL_RENDERER='Mali T860 (Panfrost)'
[vo/gpu/opengl] GL_SHADING_LANGUAGE_VERSION='1.20'
[cplayer] VO: [gpu] 1280x720 yuv420p
[cplayer] VO: Description: Shader-based GPU Renderer
Chromium GPU support on Manjaro - by krist - 04-19-2020, 06:39 AM
RE: Chromium GPU support on Manjaro - by krist - 04-20-2020, 04:16 AM
RE: Chromium GPU support on Manjaro - by llsf - 04-20-2020, 05:03 AM
RE: Chromium GPU support on Manjaro - by krist - 04-20-2020, 06:34 AM
RE: Chromium GPU support on Manjaro - by maxjrh - 04-20-2020, 06:40 AM
RE: Chromium GPU support on Manjaro - by krist - 04-20-2020, 06:58 AM
RE: Chromium GPU support on Manjaro - by krist - 04-20-2020, 02:20 PM
RE: Chromium GPU support on Manjaro - by xmixahlx - 04-20-2020, 06:20 PM
RE: Chromium GPU support on Manjaro - by krist - 05-01-2020, 12:50 PM
  Official Debian support moonwalkers 63 52,985 05-16-2024, 11:00 PM
Last Post: rempfer
  Manjaro Sway Theme Broken Eighty8 1 360 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,835 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 400 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,296 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,403 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 472 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 990 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,077 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 2,052 08-21-2023, 09:08 PM
