Raspberry Pi 7" Touchscreen Display not work?
(05-05-2016, 08:17 AM)Paara Wrote: Hi
Is it possible, that i can't use the RasPi 7" Touchscreen? Huh It seems that the ribbon cable is a millimeter too wide...
Has someone already made to work?
Paara
It is not possible as is, very LCD panel need be to customize. However, if you know how to make a flex cable converter, it may work. Another issue is the RPi LCD screen resolution is lower than Pine A64 one and this also need to adjust. Too many works.
RE: Raspberry Pi 7" Touchscreen Display not work? - by tllim - 05-05-2016, 08:47 AM
  What other devices can the LCD screen work on? kodachrome 1 3,131 12-07-2019, 06:50 PM
Last Post: kodachrome
  Search Compatible 10.1" touchscreen alfredo78 0 2,197 07-06-2018, 03:48 AM
Last Post: alfredo78
  Larger LCD touchscreen stephen fleming 3 4,755 06-13-2017, 03:16 AM
Last Post: mbt28
  Armbian display manager issues modsbyus 0 2,749 02-08-2017, 06:18 PM
Last Post: modsbyus
  8inch display compatible to FY07024DI26A30-D mbt28 0 2,361 01-26-2017, 10:07 AM
Last Post: mbt28
  lcd and hdmi dual display jodybrown99 8 11,494 11-12-2016, 08:07 PM
Last Post: Chisel_86
  Touchscreen display mods atomicSoC 2 4,201 08-26-2016, 05:44 PM
Last Post: pfeerick
  LCD Panel Connected but does not work maipercaso 1 3,025 08-20-2016, 08:14 PM
Last Post: MarkHaysHarris777
  Trouble with LCD display jdmwrx94 3 4,785 07-25-2016, 12:21 PM
  Touchscreen support? NoahJ 12 15,738 07-09-2016, 12:01 PM
Last Post: yodermk
