Armbian display manager issues
I have the pine64 2gb board with the touch LCD running armbian. everything with the LCD and touchscreen works. I am working on trying to get the display manager to work. When you boot it up, it does the autologin to the desktop for the user created on first run. Armbian uses the nodm (no display manager) by default. I removed that and installed lightdm as suggested on the getting started section on the armbian site. After rebooting I am presented with terminal only. I can login as what ever user I want and then run startx to get to the desktop but I still can't log out, or switch users or at any point get presented with a graphical login screen. If I remove lightdm and reinstall nodm it goes back to doing the autologin to the desktop.
Any wise folks run into this before?
  Adjust brightness of LCD on Armbian Desktop with 1 click JulianM 0 3,289 04-02-2017, 09:23 AM
Last Post: JulianM
  8inch display compatible to FY07024DI26A30-D mbt28 0 2,349 01-26-2017, 10:07 AM
Last Post: mbt28
  lcd and hdmi dual display jodybrown99 8 11,453 11-12-2016, 08:07 PM
Last Post: Chisel_86
  Touchscreen display mods atomicSoC 2 4,185 08-26-2016, 05:44 PM
Last Post: pfeerick
  Trouble with LCD display jdmwrx94 3 4,757 07-25-2016, 12:21 PM
Bug Raspberry Pi 7" Touchscreen Display not work? Paara 2 5,491 05-05-2016, 08:47 AM
  Touch Display Detail manny89 8 12,829 01-21-2016, 02:23 PM
Last Post: genpix
