Larger LCD touchscreen
Are there any plans on introducing a larger LCD touchscreen? I used the 7 inch LCD touchscreen with Linux and decided that it was too small for me.
Maybe you can use the screens they were using in the laptops. They are edp but you there are schematics you can make edp2dsi converter.
Not out of the box, the LCD RGB interface is multiplexed with the RGMII interface for Gigabit Ethernet, so you can't use the same Analogix bridge...
So do you mean some of the high speed ports shared with gigabit Ethernet due to that it is not possible to use the bridge?
  Search Compatible 10.1" touchscreen alfredo78 0 2,182 07-06-2018, 03:48 AM
Last Post: alfredo78
  Touchscreen display mods atomicSoC 2 4,171 08-26-2016, 05:44 PM
Last Post: pfeerick
  Touchscreen support? NoahJ 12 15,623 07-09-2016, 12:01 PM
Last Post: yodermk
  Large multi touch touchscreen for P64? vedranius 5 7,437 05-20-2016, 09:43 PM
Bug Raspberry Pi 7" Touchscreen Display not work? Paara 2 5,464 05-05-2016, 08:47 AM
  Touchscreen monitor to use lefartenshisten 1 3,534 04-30-2016, 10:47 PM
Last Post: MichaelMeissner
  Touchscreen Alternatives NoahJ 10 15,464 03-10-2016, 04:35 AM
Last Post: Fr0z7y
  Petition thread for screen larger than 7inch MostHated 4 5,358 03-02-2016, 03:40 PM
Last Post: MostHated
