Serial port cable
(03-10-2020, 02:16 AM)danielt Wrote:
(03-09-2020, 06:00 PM)tllim Wrote: Should works :-)
I don't think it does.
For me the excessive voltage level on the adapter TX/PBP RX pin causes the kernel to crash during boot up. My laptop wasn't physically damaged by the over-volting from the adapter but since it doesn't work anyway I saw no reasons to take risks and stopped using it.
I now use a 3.3v TTL adapter from eBay with a hand soldered 3.5mm adapter.
The crash during boot might be unrelated to the voltage:
"Note: It is not recommended to connect the serial adapter to pin 10 (RX) while booting, as this often causes the board to hang early in the bootloader. Disconnecting pin 10 still allows the serial console to be viewed, and it can be reconnected after the board boots, allowing interaction with the console."
https://nixos.wiki/wiki/NixOS_on_ARM/PIN...al_console
Regardless, Pine should sell a 3.3V adapter, with the correct chipset.   I have no idea why they are selling a 5V adapter when, as far as I know, none of the Pine computers use 5V UART.
Serial port cable - by bsammon - 03-06-2020, 04:11 PM
RE: Serial port cable - by tllim - 03-09-2020, 06:00 PM
RE: Serial port cable - by z4v4l - 03-09-2020, 07:06 PM
RE: Serial port cable - by danielt - 03-10-2020, 02:16 AM
RE: Serial port cable - by zaius - 03-10-2020, 11:56 AM
RE: Serial port cable - by danielt - 03-11-2020, 08:53 AM
RE: Serial port cable - by zaius - 03-11-2020, 01:00 PM
RE: Serial port cable - by danielt - 03-11-2020, 02:41 PM
RE: Serial port cable - by zaius - 03-13-2020, 12:37 PM
RE: Serial port cable - by danielt - 03-16-2020, 08:18 AM
RE: Serial port cable - by zaius - 03-16-2020, 12:44 PM
RE: Serial port cable - by vrabac - 03-10-2020, 12:25 AM
RE: Serial port cable - by z4v4l - 03-11-2020, 03:37 PM
RE: Serial port cable - by danielt - 03-12-2020, 04:48 AM
RE: Serial port cable - by xyzzy - 11-18-2020, 09:59 PM
RE: Serial port cable - by mattpenn - 03-03-2021, 08:32 AM
RE: Serial port cable - by tllim - 03-04-2021, 12:49 AM
RE: Serial port cable - by mattpenn - 03-04-2021, 10:00 AM
  serial cable 2023 thread bsammon 2 1,298 07-20-2023, 10:13 AM
Last Post: bsammon
  How are people finding the type-A USB 3.0 port? chris88233 1 1,053 10-01-2022, 01:04 AM
Last Post: LivingLinux
  Fried the charger port and USB leapylee 1 1,648 01-12-2022, 03:32 AM
Last Post: Danct12
  Pinebook Pro - Display cable broken? snokis 0 1,545 08-17-2021, 11:30 AM
Last Post: snokis
  [SOLVED] Red light flashes next to barrel-port Carl 31 43,571 01-18-2021, 09:34 AM
Last Post: dsimic
  Serial console accessible from outside as400 4 5,349 10-23-2020, 11:21 AM
Last Post: as400
  Pinebook Pro doesn't boot most of the time unless connected via USB-serial! nib0 16 13,669 09-29-2020, 10:24 PM
  Charging via USB-C Port tyha 15 20,424 07-22-2020, 08:15 PM
Last Post: iscmob
  Save your sanity: If you buy a PBP, buy a serial adapter and USB to eMMC adapter. Syonyk 11 13,230 06-30-2020, 10:28 AM
Last Post: manawyrm
Photo Looking for a PBP NVMe/SSD cable ab1jx 13 14,840 06-07-2020, 01:24 PM
Last Post: ab1jx
