How are people finding the type-A USB 3.0 port?
It appears that nearly all USB 3 supporting devices I try won't work on the type-A USB 3.0 port of the Pinebook Pro. I believe this is a power draw issue from what I've read, although it doesn't entirely match up with what I'm seeing.
  • TP-Link 1G Ethernet adapter - Left port: "Cannot enable. Maybe the USB cable is bad?". Right port: Works as a USB 2.0 device.
  • WD My Passport 2.5" spinning disk - Left port: Half-spins up, clicks, spins down, repeat. Right port: Works as a USB 2.0 device.
  • Inateck disk enclosure with SATA SSD disk - Left port: Works as a USB 2.0 device. Right port: Works as a USB 2.0 device.
  • Some generic SD card reader - Left port: Works as USB 3.0 device! Right port: Didn't bother trying.
The way I'm confirming the speed is with `lsusb -t -v`.
What's a little unexpected is that devices that appear to draw too much power for USB 3.0 will work  as USB 2.0. What's also unexpected is that something like a SATA SSD or ethernet adapter is drawing too much power for the PBP.
Does this match up with what other people are seeing? I have very few type-C devices, but is there the chance a type-C external drive is going to work better on the PBP? I know a suggestion is to use a powered USB hub, and I could get one, but that's a definite drag on portability.
This is on a Pinebook Pro which was shipped to me around August this year.
Thanks!
First batch ANSI PBP here. Same behaviour.
There are Y cables to draw power from two USB ports.
But I use a powered USB-C hub, as that can power the hub and the PBP at the same time.
Probably best to get a 30W (or more) USB-C power adapter.
  Fried the charger port and USB leapylee 1 1,611 01-12-2022, 03:32 AM
Last Post: Danct12
  Serial port cable bsammon 17 24,590 03-04-2021, 10:00 AM
Last Post: mattpenn
  Finding and adding new programs/apps James Good 3 3,463 02-27-2021, 05:41 PM
Last Post: User 17828
  [SOLVED] Red light flashes next to barrel-port Carl 31 42,768 01-18-2021, 09:34 AM
Last Post: dsimic
  Charging via USB-C Port tyha 15 20,160 07-22-2020, 08:15 PM
Last Post: iscmob
  USB-C to Display Port adapter recommendation 1920x1200 (HP ZR24w) cloudnaut 0 1,908 03-28-2020, 05:58 AM
Last Post: cloudnaut
