battery protection
(02-08-2020, 04:36 PM)PineDrone Wrote:
(01-30-2020, 04:13 AM)dukla2000 Wrote: A couple of days ago on IRC there was some discussion about the battery in 1 developer edition handset being exceptionally hard to remove. The avoidance there was to loosen one of the screws holding the mid-plane chassis, but the engineers were curious about the sporadic nature of the problem. I wonder if this is related, i.e. if @chris_02 battery fit is tighter than average?
Watch this space!
I had the same problem.  Even after loosening the surrounding screws it took a little careful prying to get it out.  I was able to remove the plastic piece and replace the battery but it's still difficult to get out without a small screw driver to pry it out.
No problem removing !
Did you remove the battery lifting from the lower end where there is the little notch,
NOT the contact end of the battery.!
    Possible to damage the contacts if you lift it from the top end..!
   “Sent from my Brave Heart Phone"
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
battery protection - by chris_02 - 01-29-2020, 07:20 AM
RE: battery protection - by murak - 01-29-2020, 08:59 AM
RE: battery protection - by Leiaz - 01-29-2020, 12:06 PM
RE: battery protection - by dukla2000 - 01-30-2020, 04:13 AM
RE: battery protection - by PineDrone - 02-08-2020, 04:36 PM
RE: battery protection - by bcnaz - 02-08-2020, 05:06 PM
RE: battery protection - by murak - 02-01-2020, 12:19 PM
RE: battery protection - by James - 02-12-2020, 11:22 AM
RE: battery protection - by dukla2000 - 02-12-2020, 01:29 PM
RE: battery protection - by soyrunner - 02-12-2020, 02:51 PM
  Megi's Kernel and Battery Life biketool 3 2,215 01-09-2023, 11:33 PM
Last Post: Canyonless
  PinePhone Pro battery life Barugon 17 15,931 07-29-2022, 09:23 AM
Last Post: prog-amateur
  postmarketOS fixed battery issues Deadladyofclowntown 1 1,574 06-23-2022, 02:44 PM
Last Post: zer0sig
  Phone won't suspend, battery drains quickly nelstomlinson 12 7,468 04-05-2022, 06:11 AM
Last Post: Anna
  The modem switch affects the connection to battery? JohnDoe 2 2,104 03-30-2022, 12:02 AM
Last Post: JohnDoe
  improve battery life on pine phone beta? taoschx 0 1,095 02-28-2022, 06:24 AM
Last Post: taoschx
  Guide to power off the Pinephone on low battery Ulfnic 1 1,598 02-06-2022, 05:16 AM
Last Post: Ulfnic
Question Is there a way to increase the battery life of the PinePhone? Avisando 18 12,699 01-22-2022, 11:55 PM
Last Post: bcnaz
  Battery Charger? JesusGod-Pope666.Info 9 6,695 12-01-2021, 09:00 AM
Last Post: JesusGod-Pope666.Info
  Battery life: Maybe really a hardware issue? KNERD 34 22,431 09-23-2021, 01:11 PM
