Boot from SD and edit screen res on native OS?
(01-27-2020, 08:01 AM)tophneal Wrote:
(01-27-2020, 06:32 AM)dhosh Wrote:
(01-27-2020, 05:57 AM)xmixahlx Wrote: I am not sure about how manjaro does this... we're you using kde or xfce?
my first thought is to jump to a console and load a different window manager and see what happens... my go-tos are fluxbox and sway.
"system wide" sounds like a config file
Yes... That's what I'm looking for. . the display/monitor config file where the change I made in the default is .  I'm booting to Manjaro on SD card, then using terminal to go to the internal drive where the default OS is located.  I assume it's in it's /etc folder.  I thought I had found it, edited the Tex file, saved, then shut down and pulled the SD/Manjaro card and attempted to boot from the internal drive again.  Still no go.  I can log in, and it seems to finish booting , but don't get a desktop screen after... Just a blank screen.
I can't make any changes in the GUI when booted from Manjaro, as it will only effect Manjaro on the SD... Not the internal OS config.  So, I am booting from Manjaro to make a manual change on the default internal drive.  Does that make sense?
Per this post, you need to make your edits to the xrandr config.
Very good!  I'll look at the post tonight.  I did make a change to one of the files in that folder, and it didn't work... But I'll read the list and re-attemot.  I likely missed something!
Thanks!
Dennis Hoshield
PBPro/ANSI/Manjaro
RE: Boot from SD and edit screen res on native OS? - by dhosh - 01-27-2020, 08:17 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 309 02-23-2024, 04:22 PM
Last Post: tuxxpine
  uboot wont boot to SD card after upgrade jbradley419 7 881 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 301 01-16-2024, 09:17 AM
Last Post: jbradley419
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,251 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 708 12-13-2023, 08:17 PM
Last Post: trillobite
  Various freezes during boot & while running several Linux distros - hardware error? donuts 1 601 11-22-2023, 11:47 AM
Last Post: fxc
  Cannot boot to Kali SD card after uboot upgrade jbradley419 4 1,207 09-19-2023, 08:48 AM
Last Post: dachalife
  Does latest Tow-Boot install/work correctly for everyone? tophneal 4 1,911 08-03-2023, 03:30 PM
  Black screen by start up bluedemon382 10 3,019 07-27-2023, 07:49 AM
Last Post: dstallmo
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 811 07-13-2023, 01:50 PM
Last Post: PaulQ
