Cannot boot to Kali SD card after uboot upgrade
I recently upgraded uboot after upgrading manjaro and it suggesting a uboot upgrade.  I am now unable to boot to my Kali SD card image as I could previously.
This is unfortunately very common. Hopefully your Manjaru doesn't quit working, preventing you from booting at all.
The solution is to install a different U-Boot, or Tow-Boot.
:wq
[ SRA accepts you ]
(09-19-2023, 07:11 AM)KC9UDX Wrote: This is unfortunately very common.  Hopefully your Manjaru doesn't quit working, preventing you from booting at all.
appreciate the response.  Do you have a preference U-Boot or Tow-Boot?  And is there any good documentation for installation or reinstallation?
You could check /var/cache/pacman/pkg/uboot* for the previous version
You can also freely download the U-Boot manual and customize yours. I'm using U-Boot for the PBP (Kali), Tow Boot on the PP (Mobian, had to switch for an update) and haven't had to change anything on the PT2.
Satisfied PinePhone, Pinebook Pro & PineTab2 owner; Thank you Pine64Team for your work!  Smile
  uboot wont boot to SD card after upgrade jbradley419 7 831 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 293 01-16-2024, 09:17 AM
Last Post: jbradley419
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,229 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 698 12-13-2023, 08:17 PM
Last Post: trillobite
  Various freezes during boot & while running several Linux distros - hardware error? donuts 1 587 11-22-2023, 11:47 AM
Last Post: fxc
  Will it be possible to upgrade the Pinebook Pro if/when a newer model is released? Rat24 4 1,437 09-15-2023, 03:00 PM
  Does latest Tow-Boot install/work correctly for everyone? tophneal 4 1,878 08-03-2023, 03:30 PM
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 802 07-13-2023, 01:50 PM
Last Post: PaulQ
  New Pinebook pro won’t boot Generaltuxenburg 4 1,948 06-14-2023, 07:20 AM
Tongue Yet another Pinebook Pro won't boot thread pinemouth 4 2,441 05-20-2023, 01:02 AM
Last Post: jackwilson
