Boot from SD and edit screen res on native OS?
(01-27-2020, 05:57 AM)xmixahlx Wrote: I am not sure about how manjaro does this... we're you using kde or xfce?
my first thought is to jump to a console and load a different window manager and see what happens... my go-tos are fluxbox and sway.
"system wide" sounds like a config file
Yes... That's what I'm looking for. . the display/monitor config file where the change I made in the default is .  I'm booting to Manjaro on SD card, then using terminal to go to the internal drive where the default OS is located.  I assume it's in it's /etc folder.  I thought I had found it, edited the Tex file, saved, then shut down and pulled the SD/Manjaro card and attempted to boot from the internal drive again.  Still no go.  I can log in, and it seems to finish booting , but don't get a desktop screen after... Just a blank screen.
I can't make any changes in the GUI when booted from Manjaro, as it will only effect Manjaro on the SD... Not the internal OS config.  So, I am booting from Manjaro to make a manual change on the default internal drive.  Does that make sense?
Dennis Hoshield
PBPro/ANSI/Manjaro
RE: Boot from SD and edit screen res on native OS? - by dhosh - 01-27-2020, 06:32 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 344 02-23-2024, 04:22 PM
Last Post: tuxxpine
  uboot wont boot to SD card after upgrade jbradley419 7 998 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 333 01-16-2024, 09:17 AM
Last Post: jbradley419
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,397 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 782 12-13-2023, 08:17 PM
Last Post: trillobite
  Various freezes during boot & while running several Linux distros - hardware error? donuts 1 647 11-22-2023, 11:47 AM
Last Post: fxc
  Cannot boot to Kali SD card after uboot upgrade jbradley419 4 1,277 09-19-2023, 08:48 AM
Last Post: dachalife
  Does latest Tow-Boot install/work correctly for everyone? tophneal 4 1,999 08-03-2023, 03:30 PM
  Black screen by start up bluedemon382 10 3,155 07-27-2023, 07:49 AM
Last Post: dstallmo
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 830 07-13-2023, 01:50 PM
Last Post: PaulQ
