Charging Issue
(01-24-2020, 12:16 AM)Soul_Hacker Wrote: I have the same setup, ANSI with europe adapter.
I don't have this issue, tho i always use some sort of USB port.
Can you try charging with USB-C? or with the USB-to-Barrel charging cable?
And maybe try charging with a normal USB output (5V)?
Anyway if you can feel the current, something is very off... please be careful.
yeah i don't have a USB-C charger, or the USB-to-barrel cable though those seems like a good idea. i guess i need to go out and buy one of these things & test it.
how would i charge with 5V from the packaged power adaptor? it says 5V on it but... i believe that may not be the truth.
Charging Issue - by judgeruss - 01-23-2020, 02:46 PM
RE: Charging Issue - by xmixahlx - 01-23-2020, 08:56 PM
RE: Charging Issue - by Soul_Hacker - 01-24-2020, 12:16 AM
RE: Charging Issue - by judgeruss - 01-24-2020, 02:32 AM
RE: Charging Issue - by Soul_Hacker - 01-25-2020, 03:43 AM
RE: Charging Issue - by jpakkane - 01-24-2020, 02:53 AM
RE: Charging Issue - by judgeruss - 01-24-2020, 03:17 AM
RE: Charging Issue - by amooke - 01-24-2020, 07:36 PM
RE: Charging Issue - by pfeerick - 01-25-2020, 03:54 AM
Photo P{inebook Pro not charging Ome Ko 6 2,075 11-09-2023, 03:29 PM
Last Post: tomekdev
  Newbie with immediate issue jasonumd 1 1,008 03-04-2023, 05:59 PM
Last Post: hacknix
  Pine Book Pro Charging Problems balin 7 6,993 12-15-2022, 02:15 PM
Last Post: tomasgreenro
  suckless surf on arch linux pinebook pro scrolling issue gehn5 0 998 04-16-2022, 07:41 PM
Last Post: gehn5
  Very low battery (but charging) causes boot failures Phillip Bell 7 4,600 02-22-2022, 11:20 AM
Question USB-C Video Out Issue dev 2 1,894 02-08-2022, 07:28 PM
Last Post: dev
  Pinebook Pro Stopped Charging via USB-C MickTheGeek 4 4,370 08-25-2021, 02:51 PM
Last Post: MickTheGeek
  HArdware issues while charging user18130814200115 2 2,864 05-01-2021, 04:13 AM
Last Post: gabeeg
  PineBookPro does not charging floppy_rofling 0 1,668 02-03-2021, 05:29 AM
Last Post: floppy_rofling
  Screen flicker with USB-C charging bchenlee609 5 5,932 01-25-2021, 08:48 PM
Last Post: bchenlee609
