PineBookPro does not charging
Hello , I met with problem my PineBookPro doesn't want to charge .
The charging block kinda work but accumulator shows low power .
I tried to charge him 24 hour but it still low power .
The red lamp near to power input is blinking red (when it real charging lamp doesn't blinkin')
Hope for ure advise .
  Charging problem RicTor 4 2,866 07-28-2026, 08:10 PM
  PineNote v1.2 - Charges Never Enter "Charging" State (Factory OS, RK817 Below Minimum ttsp 0 1,541 07-02-2026, 02:52 AM
Last Post: ttsp
Photo P{inebook Pro not charging Ome Ko 6 7,463 11-09-2023, 03:29 PM
Last Post: tomekdev
  PinebookPro Display Corrupts/Cuts Out Twig 5 7,088 06-11-2023, 07:59 AM
  Manjaro pinebookpro images with kernel 5.7.19 rfm83 11 14,845 01-22-2023, 10:05 PM
Last Post: rfm83
  Pine Book Pro Charging Problems balin 7 14,287 12-15-2022, 02:15 PM
Last Post: tomasgreenro
  PinebookPro CPU Speed setting therosery 0 2,125 09-07-2022, 05:02 AM
Last Post: therosery
  Very low battery (but charging) causes boot failures Phillip Bell 7 11,187 02-22-2022, 11:20 AM
  PinebookPro Build Errors mexsudo 3 6,351 01-30-2022, 08:36 AM
Last Post: mexsudo
  Pinebook Pro Stopped Charging via USB-C MickTheGeek 4 9,023 08-25-2021, 02:51 PM
Last Post: MickTheGeek
