HArdware issues while charging
While charging my pinebook pro, two things happen.
First, a sort of static noise starts playing through the headphone jack. This is especially noticeable if I attach external speakers to the headphone jack. Funnily enough, this noise gets louder if the device is powered off.
Second, the trackpad stops working properly. It often detects two fingers instead of one and the movement is jittery and inaccurate.
I am using the official charger in the barrel port. Does anyone else have these issues? And (though I doubt it sincec this seems to be a hardware problem) is there a fix?
I've had all those things with USB-C charging, with certain chargers, but not on barrel.
Yep, for me since the last Manjaro update I get the issue with USB-C charging and the Trackpad getting jumpy and unresponsive.
  Various freezes during boot & while running several Linux distros - hardware error? donuts 1 584 11-22-2023, 11:47 AM
Last Post: fxc
Photo P{inebook Pro not charging Ome Ko 6 1,997 11-09-2023, 03:29 PM
Last Post: tomekdev
  Issues with T-Mobile Home Internet? skinnyonthebebop 3 1,087 10-17-2023, 07:42 AM
Last Post: skinnyonthebebop
  Pine Book Pro Charging Problems balin 7 6,903 12-15-2022, 02:15 PM
Last Post: tomasgreenro
  Got a PBP - batch(August/September) and the audio is not good(2 big issues) crazyquark 2 1,490 10-01-2022, 10:16 AM
Last Post: crazyquark
  MiniConda Install Issues nixyhustle 0 784 09-16-2022, 10:06 PM
Last Post: nixyhustle
  new PBP issues jpjnh 9 3,900 08-22-2022, 07:26 AM
  Very low battery (but charging) causes boot failures Phillip Bell 7 4,519 02-22-2022, 11:20 AM
  Issues with External Display After Recent Update reundo 0 1,375 11-18-2021, 06:37 PM
Last Post: reundo
  Pinebook Pro Stopped Charging via USB-C MickTheGeek 4 4,293 08-25-2021, 02:51 PM
Last Post: MickTheGeek
