Kodi on Manjaro
(01-03-2020, 12:14 PM)brent.thierens Wrote: Hi
I am trying to run Kodi on Manjaro Linux. After compiling, Kodi runs, but video playback is very slow (1-2 FPS). The same video plays just fine with mpv player or smplayer. I used the PKGBUILD from the x64 Kodi, Kodi-git didn't like custom compile flags.
I tried compiling with the options provided in the default PKGBUILD. I also edited it to include
-DX11_RENDERING_SYSTEM=GLES
that didn't help. I also added flags for
-DENABLE_GL=OFF
-DENABLE_GLES=ON
-DENABLE_VAAPI=OFF
-DENABLE_VDPAU=OFF
didn't make a difference.
Given the fact that ffmpeg seems to handle the video just fine (mpv is a frontend for ffmpeg, right?), I also tried compiling with
-DWITH_FFMPEG=SHARED
to use the ffmpeg from the system, but no luck.
I tried using it on Manjaro, my last tests were with the Panfrost driver active. I also tried once with GL4ES. In order to speed up the build, I only compiled kodi-x11, not kodi-gbm or kodi-wayland.
Worth to mention: on Debian Kodi works fine (although it's a much older version).
Getting it to work in the first place is a good achievement. I would like to work on kodi package with you But I can just compile and test if while you can do the research for what needs to be the compile arguments. running Kodi in gbm would be the smoothest option I can think of.
If you have a kodi pkg for manjaro then please share it I can look into it and see how we can optimize it. also please point me to the PKGBUILD you used so we can work on it together.
Manjaro ARM Team.
Kodi on Manjaro - by brent.thierens - 01-03-2020, 12:14 PM
RE: Kodi on Manjaro - by vrabac - 02-25-2020, 05:56 AM
RE: Kodi on Manjaro - by spikerguy - 03-05-2020, 06:44 AM
RE: Kodi on Manjaro - by brent.thierens - 03-08-2020, 09:25 AM
RE: Kodi on Manjaro - by spikerguy - 03-09-2020, 08:43 AM
RE: Kodi on Manjaro - by spikerguy - 03-09-2020, 03:24 PM
RE: Kodi on Manjaro - by brent.thierens - 03-10-2020, 07:42 AM
RE: Kodi on Manjaro - by spikerguy - 03-11-2020, 08:06 AM
RE: Kodi on Manjaro - by vrabac - 03-16-2020, 07:28 AM
RE: Kodi on Manjaro - by spikerguy - 03-16-2020, 09:10 AM
RE: Kodi on Manjaro - by brent.thierens - 03-12-2020, 01:15 AM
RE: Kodi on Manjaro - by spikerguy - 03-12-2020, 08:18 AM
RE: Kodi on Manjaro - by vrabac - 03-12-2020, 06:09 AM
  Manjaro Sway Theme Broken Eighty8 1 406 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,849 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 457 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,332 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,461 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 516 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 1,044 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,088 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 2,068 08-21-2023, 09:08 PM
  Manjaro - HIbernate - brcmfmac clk issue pompeyPinePro 1 867 08-18-2023, 02:06 AM
Last Post: juliamenendez
