Kodi on Manjaro
Hi
I am trying to run Kodi on Manjaro Linux. After compiling, Kodi runs, but video playback is very slow (1-2 FPS). The same video plays just fine with mpv player or smplayer. I used the PKGBUILD from the x64 Kodi, Kodi-git didn't like custom compile flags.
I tried compiling with the options provided in the default PKGBUILD. I also edited it to include
-DX11_RENDERING_SYSTEM=GLES
that didn't help. I also added flags for
-DENABLE_GL=OFF
-DENABLE_GLES=ON
-DENABLE_VAAPI=OFF
-DENABLE_VDPAU=OFF
didn't make a difference.
Given the fact that ffmpeg seems to handle the video just fine (mpv is a frontend for ffmpeg, right?), I also tried compiling with
-DWITH_FFMPEG=SHARED
to use the ffmpeg from the system, but no luck.
I tried using it on Manjaro, my last tests were with the Panfrost driver active. I also tried once with GL4ES. In order to speed up the build, I only compiled kodi-x11, not kodi-gbm or kodi-wayland.
Worth to mention: on Debian Kodi works fine (although it's a much older version).
Kodi on Manjaro - by brent.thierens - 01-03-2020, 12:14 PM
RE: Kodi on Manjaro - by vrabac - 02-25-2020, 05:56 AM
RE: Kodi on Manjaro - by spikerguy - 03-05-2020, 06:44 AM
RE: Kodi on Manjaro - by brent.thierens - 03-08-2020, 09:25 AM
RE: Kodi on Manjaro - by spikerguy - 03-09-2020, 08:43 AM
RE: Kodi on Manjaro - by spikerguy - 03-09-2020, 03:24 PM
RE: Kodi on Manjaro - by brent.thierens - 03-10-2020, 07:42 AM
RE: Kodi on Manjaro - by spikerguy - 03-11-2020, 08:06 AM
RE: Kodi on Manjaro - by vrabac - 03-16-2020, 07:28 AM
RE: Kodi on Manjaro - by spikerguy - 03-16-2020, 09:10 AM
RE: Kodi on Manjaro - by brent.thierens - 03-12-2020, 01:15 AM
RE: Kodi on Manjaro - by spikerguy - 03-12-2020, 08:18 AM
RE: Kodi on Manjaro - by vrabac - 03-12-2020, 06:09 AM
  Manjaro Sway Theme Broken Eighty8 1 312 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,786 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 364 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,207 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,286 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 432 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 927 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,044 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 2,010 08-21-2023, 09:08 PM
  Manjaro - HIbernate - brcmfmac clk issue pompeyPinePro 1 788 08-18-2023, 02:06 AM
Last Post: juliamenendez
