New NVMe SSD not seen by OSes
(12-24-2019, 09:23 PM)Arwen Wrote: Never will work, sorry. Return it if you can. From the product title, you bought a SATA type M.2 SSD;
Quote:MyDigitalSSD Super Boot 2 (SB2) 42mm (2242) SATA III (6G) M.2 NGFF SSD Solid State Drive (512GB (480GB))
The NVMe adapter in our Pinebook Pros only supports PCIe type, (& NVMe). Ideally a M.2 with M key only would be used, (4 x PCIe lanes for maximum speed). Here is the description;
https://en.wikipedia.org/wiki/M.2#Form_f...and_keying
But, both B & M key PCIe NVMe SSDs can be used, as long as you understand the SATA & USB part won't work in a Pinebook Pro.
I thought I had read that only M keyed (excluding M + B) M.2 SSDs would work in the adapter, but can't find the reference anymore so I may have misread it.  Either way, thanks for the clarification.  I was wondering why the only 42mm SSD listed as working in the wiki was keyed B+M, and found this post while searching for the answer.  So the issue is not with the additional B key, but with the SATA interface.  Looking at Newegg, it appears that their filtering should make this easier.  You can select both the form factor (M.2 along with the size code) and the interface (PCI express), and that brings up the Sabrient drives and the Toshiba RC100.
(12-25-2019, 08:26 AM)tophneal Wrote: I have certainly run across the Sabrent SSDs, but couldn't locate enough information about their power consumption/usage.
I was looking for that as well, and couldn't find it even after consulting the user guide. On Monday I submitted a question on the power states to their presales department.  So far I only have an email acknowledging the question, but once I hear back I'll post the answer.
Another 42mm pcie drive that looks promising is the Lexar NM520 M.2 2242 256GB NVMe Solid-State Drive (LNM520-256RBNA).  From the description at Amazon:
  • Ideal for smaller notebooks
  • Upgrade from SATA to an entry-level PCIe NVMe performance
  • Faster speeds of up to 1650MB/s read and 1000MB/s write 1
  • Get 2. 5x the speed of a SATA-based SSD
New NVMe SSD not seen by OSes - by tophneal - 12-24-2019, 07:41 PM
RE: New NVMe SSD not seen by OSes - by Arwen - 12-24-2019, 09:23 PM
RE: New NVMe SSD not seen by OSes - by Redbeard - 01-08-2020, 12:18 PM
RE: New NVMe SSD not seen by OSes - by tophneal - 12-24-2019, 10:49 PM
RE: New NVMe SSD not seen by OSes - by bcnaz - 01-26-2020, 12:44 AM
RE: New NVMe SSD not seen by OSes - by tophneal - 01-26-2020, 09:08 AM
RE: New NVMe SSD not seen by OSes - by xmixahlx - 12-24-2019, 11:52 PM
RE: New NVMe SSD not seen by OSes - by Arwen - 12-25-2019, 03:58 AM
RE: New NVMe SSD not seen by OSes - by Musse - 01-24-2020, 08:26 PM
RE: New NVMe SSD not seen by OSes - by Arwen - 01-25-2020, 05:55 AM
RE: New NVMe SSD not seen by OSes - by as400 - 12-25-2019, 07:22 AM
RE: New NVMe SSD not seen by OSes - by tophneal - 12-25-2019, 08:26 AM
New NVMe SSD not seen by OSes - by tophneal - 12-25-2019, 10:54 AM
RE: New NVMe SSD not seen by OSes - by Arwen - 12-25-2019, 02:22 PM
  New Working nVME gilwood 0 258 02-12-2024, 08:46 AM
Last Post: gilwood
  NVME problems 2022 / Intel 660p 1TB Starbug 1 1,595 04-04-2023, 12:16 PM
Last Post: globaltree
Thumbs Up NVMe adapter, Great addition dachalife 2 1,865 11-28-2022, 12:56 PM
Last Post: dachalife
  NVMe drives not detected mattpenn 12 10,601 03-05-2022, 04:53 AM
Last Post: mattpenn
  NVme intall usage? tkudog 2 2,951 03-04-2022, 01:29 AM
Last Post: Tazdevl
  Anyone selling a spare NVMe adapter in Europe? tom.tomasz 1 1,894 01-03-2022, 07:57 AM
Last Post: tom.tomasz
  NVMe-related crashes and instability, plus a solution simonsouth 13 14,965 12-10-2021, 07:47 PM
Last Post: josmo
  NVMe SSD testing methodology halogen 1 2,671 07-22-2021, 05:57 PM
Last Post: calinb
Question Battery stops charging and NVMe and other media disconnect randomly Eey0zu6O 4 4,877 07-09-2021, 08:45 PM
Last Post: moonwalkers
  nvme drive disappears after about an hour of uptime codebreaker 25 32,515 02-09-2021, 11:32 PM
Last Post: dsimic
