default os: loop while login as rock
Hi there
I'm using a Pinebook Pro with default OS.
Problem: Suddenly I cannot login as user rock anymore. Giving the credentials it loops and shows the login mask again and again.
I created another user before (they worked well in parallel) which is still usable.
I used User rock for update purposes. And now I do not have the update button in the lower right side anymore.
Any idea how to fix the login or do I have to reinstall from scatch?
Any help / tip is very welcome. - Thanks
Regards Adrian
default os: loop while login as rock - by gritibaenz - 12-24-2019, 07:54 AM
  No Sound on Default Manjaro KDE carlosqueso 4 5,158 04-01-2021, 07:17 AM
Last Post: carlosqueso
  Graphical login hanging after password entry mhill8 2 3,377 03-29-2021, 08:32 AM
Last Post: jacksonliam341
  PBP Went Blank After Login iscmob 2 3,003 12-07-2020, 09:28 AM
Last Post: iscmob
  Pinebook Pro Won't Accept Login GFreeman 16 16,573 09-03-2020, 11:44 AM
  Suspend with NVME not working - Default Debian appdev46 5 8,674 07-14-2020, 01:53 PM
Last Post: Jeremiah Cornelius
  Login screen issue. LinuXchoicE 2 4,140 07-07-2020, 09:06 AM
Last Post: LinuXchoicE
  Default OS update log Luke 194 278,447 06-11-2020, 11:25 PM
Last Post: xmixahlx
  OEM Script - Factory Default xmark 0 1,907 06-07-2020, 06:51 AM
Last Post: xmark
  How do you upgrade Chromium on default Debian that came with my PBP james64 6 7,943 05-26-2020, 07:21 AM
Last Post: User 6582
  Stuck on login screen Kscott6969 0 1,925 04-20-2020, 10:58 PM
Last Post: Kscott6969
