PBP Went Blank After Login
I really really enjoy PBP Manjaro for many months.
Until recently, after I keyed my login password, the login screen continued as usual for a few seconds and then the screen gone blank. I noticed the green LED and noted the laptop is still running, but with a blank screen.
I’m no Linux expert. Please advise what shall I do.
Thanks.
(12-06-2020, 09:03 AM)iscmob Wrote: Hi,
Thanks.
 I'm facing a similar issue with Fedora 33 on kernel 5.7 by armdevelopers.
However, my install switches back to the login screen after about 2 minutes, after which login works fine without crashing a second time.
What happens, when you try to switch TTY?
Is there any output on your screen when pressing the arrow keys?
Thx.
I don’t know what’s TTY.
After I keyed in my password to login, the Manjaro logo came on with a progressing bar and day/time. This screen would stay for 30sec before it went blank. Sometimes it went blank with the green power LED ON and sometimes the green LED went OFF too. You can see my attached picture.
  PBP blank screen after updating Manjaro Franko 6 2,010 04-01-2023, 07:55 AM
Last Post: hacknix
  PBP green LED works but blank display. frerebo 1 874 02-22-2023, 03:11 AM
  Graphical login hanging after password entry mhill8 2 3,365 03-29-2021, 08:32 AM
Last Post: jacksonliam341
  Pinebook Pro Won't Accept Login GFreeman 16 16,508 09-03-2020, 11:44 AM
  Login screen issue. LinuXchoicE 2 4,125 07-07-2020, 09:06 AM
Last Post: LinuXchoicE
  Stuck on login screen Kscott6969 0 1,921 04-20-2020, 10:58 PM
Last Post: Kscott6969
  default os: loop while login as rock gritibaenz 8 8,245 03-10-2020, 03:14 PM
Last Post: gritibaenz
  Can't access login evj 3 4,146 02-03-2020, 07:01 AM
Last Post: FeMike
  Blank Screen after reboot Sats 12 12,448 01-27-2020, 02:23 PM
Last Post: Sats
  Wrong keyboard Lay-out in Login and terminal Firedevil79 1 3,146 12-04-2019, 08:50 AM
Last Post: ndp
