No Sound on Default Manjaro KDE
So, I have no sound on Manjaro KDE through either the speakers or the regular headphone jack.  I think this happened after an update, and I don't think I've changed anything, but I don't use sound terribly frequently, so I may have done something.  This is what I've found out so far: I asked over in the Manjaro forum, but it appears they're stumped.  Anybody here have any troubleshooting ideas?
What I usually do when my audio settings go wrong is I copy the default alsa config from the post-install package...
https://gitlab.manjaro.org/manjaro-arm/p...ound.state
the file lives in /var/lib/alsa and contains the current config, so if you overwrite it there, you get the defaults again
(03-31-2021, 09:00 AM)xalius Wrote: What I usually do when my audio settings go wrong is I copy the default alsa config from the post-install package...
Thanks for the troubleshooting idea, but sadly, I did what you suggested and it still didn't work.  Are you able to get sound on the latest Manjaro KDE?
My old install and a new image booted from sdcard work fine so far
(04-01-2021, 05:12 AM)xalius Wrote: My old install and a new image booted from sdcard work fine so far
Hmmm....may be a time for a reinstall then when I get my hands on another SD card.
  No boot after Manjaro flash PBcurry 11 247 09-27-2022, 10:57 AM
Last Post: bburdette
  Manjaro pinebookpro images with kernel 5.7.19 rfm83 0 65 09-24-2022, 09:23 PM
Last Post: rfm83
  alarming sound coming from pinebook pro jazzhands 2 315 08-21-2022, 02:34 PM
Last Post: foobar
Big Grin EASY SOLUTION for Manjaro "Missing Keys" Update and Install Failure Zoroaster-Z 0 248 08-14-2022, 09:01 PM
Last Post: Zoroaster-Z
  Manjaro ARM new version? And hibernate/ sleep mode regretfulpineuser 0 275 06-20-2022, 02:48 PM
Last Post: regretfulpineuser
  MAC Spoofing failing in manjaro slow_motion 7 5,591 06-07-2022, 05:51 PM
  Manjaro I3 james64 1 651 03-20-2022, 03:45 PM
Last Post: jiyong
  Updated stock Manjaro, now won't boot (brick?) pineymousepad 17 5,109 02-18-2022, 02:29 PM
Last Post: jiyong
  Manjaro i3 Edition not booting mtndew 0 957 08-23-2021, 06:21 PM
Last Post: mtndew
  Games compilation howto on the Pinebook-pro (Manjaro Linux and Debian native) astr0baby 200 225,915 08-01-2021, 04:30 PM
Last Post: wpeckham
