Pinebook serial console usage
Is the Pinebook Serial Console usable with the Pinebook Pro?
On mine PBP, when I used the Pinebook serial console, it seems to lead to eMMC not responding: when plugged-in from cold boot, I got DDR initialization then it hangs; if I plug the jack after DDR initialization, I got eMMC timeout.
Here is a sample serial output, from a cold boot:
DDR Version 1.20 20190314
In
channel 0
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0 training pass!
channel 1 training pass!
change freq to 400MHz 0,1
channel 0
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
change freq to 800MHz 1,0
Channel 0: LPDDR4,800MHz
Bus Width=32 Col=10 Bank=8 Row=15/15 CS=2 Die Bus-Width=16 Size=2048MB
Channel 1: LPDDR4,800MHz
256B stride
ch 0 ddrconfig = 0x101, ddrsize = 0x2020
ch 1 ddrconfig = 0x101, ddrsize = 0x2020
pmugrf_os_reg[2] = 0x3AA1FAA1, stride = 0xD
OUT
In
soft reset
SRX
Then it hangs indefinitely. The power LED stays off.
When attaching the jack after u-boot load from eMMC:
1:      PINEBOOKPRO
2:      PINEBOOKPRO-prev-kernel
Enter choice: 1
1:      PINEBOOKPRO
Retrieving file: /Image
** Can't read partition table on 0:0 **
** Invalid partition 1 **
Skipping PINEBOOKPRO for failure retrieving kernel
Retrieving file: /Image.bak
** Unable to read file /Image.bak **
Skipping PINEBOOKPRO-prev-kernel for failure retrieving kernel
SCRIPT FAILED: continuing...
** fs_devread read error - block
Failed to mount ext2 filesystem...
** Unrecognized filesystem type **
rkparm_init_param_from_storage param read fail
RKPARM: Invalid parameter part table
mmc_bread: Re-init mmc_read_blocks error
mmc fail to send stop cmd
With the jack plugged-in but the USB plug not attached to a computer, it boots normally.
What am I doing wrong?
Pinebook serial console usage - by nemunaire - 11-08-2019, 10:25 AM
RE: Pinebook serial console usage - by zaius - 11-08-2019, 01:34 PM
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 2 540 04-09-2024, 04:33 AM
Last Post: maxjrh
  Pinebook Pro on Debian 12 Power Issue u974615 1 342 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 282 02-17-2024, 07:06 PM
  Pinebook Pro charging issues tomekdev 1 619 01-05-2024, 08:40 PM
Last Post: tomekdev
  Replacement battery for PineBook Pro DrYak 3 1,087 11-07-2023, 10:09 AM
Last Post: DrYak
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 130,245 09-13-2023, 03:43 AM
Last Post: k3dAR
  PineBook Pro dead ottahe 9 6,018 01-18-2023, 07:41 PM
Last Post: ottahe
  Pinebook Pro malfunctioned hardware samtux 10 4,421 12-27-2022, 03:31 PM
Last Post: samtux
  PineBook Pro revision 2.2: Wishlist for the hardware issue fixes dsimic 115 136,171 11-30-2022, 04:28 PM
  Decent Pinebook Pro barrel PSU / Charger petaramesh 3 1,902 10-21-2022, 07:57 AM
Last Post: dachalife
