A true mainline Linux Kernel for the Pinebook Pro
#60
Trying to boot this kernel with the stock Debian image that comes pre-installed. I built the defconfig, copied the Image and DTB onto /boot, modules into /lib/modules. It starts to boot, and then I see serial output, but suddenly after the following, it becomes garbage:
[ 12.051588] OF: graph: no port node found in /i2c@ff3d0000/fusb30x@22
[ 12.065983] OF: graph: no port node found in /i2c@ff3d0000/fusb30x@22/connector
[ 12.068329] OF: graph: no port node found in /i2c@ff3d0000/fusb30x@22/connector
Has anyone else seen this? I'm using the 1500000 baud rate, and that works fine for u-boot output and early kernel output until this point. I've tried a few other common baud rates at this point, but nothing shows reasonable output.
RE: A true mainline Linux Kernel for the Pinebook Pro - by Hexxeh - 11-28-2019, 06:14 PM
5.12 - by kalpazanius - 04-26-2021, 04:38 PM
RE: 5.12 - by ramsey - 06-19-2021, 05:36 PM
RE: 5.12 - by linuxad - 06-20-2021, 09:26 AM
  Debian on Pinebook Pro u974615 7 1,532 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 2,044 02-22-2024, 04:02 PM
  Attempting to install Void Linux, boots into a black screen 9a3eedi 0 467 02-18-2024, 08:54 AM
Last Post: 9a3eedi
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,319 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,441 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 90,867 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 1,489 11-23-2023, 07:37 AM
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,795 09-07-2023, 09:38 PM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,663 08-31-2023, 04:20 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,659 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
