Any advice for a Linux distribution for Python and data science applications?
That the PBP is ARM definitely matters.  As far as I know, there is no Anaconda for ARM, and Miniconda for ARM has limitations and does not seem well-supported.  I'm curious if there is a Jupyter kernel that will run on the PBP.
Even if you manage to get it running, it might be very slow.  So while I would not want to discourage anyone from getting a PBP, if the reason is "data science tasks under linux with python and jupyter notebook", then I would strongly consider an x86 machine.
RE: Any advice for a Linux distribution for Python and data science applications? - by zaius - 09-27-2019, 01:39 PM
  Attempting to install Void Linux, boots into a black screen 9a3eedi 0 408 02-18-2024, 08:54 AM
Last Post: 9a3eedi
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,587 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Kali Linux for Pinebook Pro - stuck on the login screen owaspfap 0 698 07-13-2023, 05:21 PM
Last Post: owaspfap
  Kali Linux for Pinebook Pro Luke 100 162,173 05-03-2023, 06:10 AM
Last Post: dachalife
  With the help of a friend, I installed a beautiful deep os distribution, but I won't wangyukunshan 0 632 03-03-2023, 10:56 PM
Last Post: wangyukunshan
  DiY - Installing Void Linux ARM On The Pinebook Pro vincele 1 1,242 11-28-2022, 05:03 PM
  Arch Linux ARM root filesystem SKiljan 24 21,280 09-24-2022, 03:11 AM
Last Post: alexandre
Information Install Void Linux with near-full-disk encryption dumetrulo 3 3,184 09-05-2022, 12:00 PM
Last Post: petersen77
  Help with Kali Linux wifi not working but works with Manjaro PineSupporter 2 2,452 08-25-2022, 02:15 PM
Last Post: Niko
  Problems installing/ booting a different Linux on PinebookPro v-man 3 3,148 03-22-2022, 06:37 PM
Last Post: pentamassiv
