The PINEBOOK Pro M.2/NGFF NVMe SSD Interface Adapter
(08-08-2019, 03:59 AM)geokon Wrote: Is there some kind of upper limit in terms of throughput for the NVMe on the SoC side of things? I assume if you get some fancy Intel Optane thing it'll start to hit some other system limits
The limit for throughput is the PCIe interface that the NVMe communications are going through. In this case, it is a PCIe v2.1 x4 link.
A single (x1) PCIe2 link has a theoretical bandwidth of 500MB/s. More lanes adds more bandwidth in increments of 500MB/s. Therefore, the x4 link can theoretically do 2000MB/s (or in simpler terms, 2GB/s).
Those are just theoretical numbers, however, and reality is imperfect. There's also control signals and whatever else that has to go over that link. Reality is likely going to be somewhere around 1.5-1.7GB/s.
(08-08-2019, 03:59 AM)geokon Wrote: And similarly for the mSD. Is there an upper limit to the class that is supported? (past which you won't see any perf benefit)
I believe that the limit for what the microSD slot can support is UHS-I. Its fastest mode is "SDR104", which provides theoretical speeds of up to 104MB/s.
RE: The PINEBOOK Pro M.2/NGFF NVMe SSD Interface Adapter - by fire219 - 08-08-2019, 02:44 PM
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 2 547 04-09-2024, 04:33 AM
Last Post: maxjrh
  Pinebook Pro on Debian 12 Power Issue u974615 1 346 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 288 02-17-2024, 07:06 PM
  New Working nVME gilwood 0 230 02-12-2024, 08:46 AM
Last Post: gilwood
  Pinebook Pro charging issues tomekdev 1 627 01-05-2024, 08:40 PM
Last Post: tomekdev
  Replacement battery for PineBook Pro DrYak 3 1,107 11-07-2023, 10:09 AM
Last Post: DrYak
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 130,489 09-13-2023, 03:43 AM
Last Post: k3dAR
  NVME problems 2022 / Intel 660p 1TB Starbug 1 1,561 04-04-2023, 12:16 PM
Last Post: globaltree
  PineBook Pro dead ottahe 9 6,027 01-18-2023, 07:41 PM
Last Post: ottahe
  Pinebook Pro malfunctioned hardware samtux 10 4,429 12-27-2022, 03:31 PM
Last Post: samtux
