Received my NAS case
Hi Folks,
I've received my NAS case, SATA PCIe HBA and other bits.
On first look, the case is well designed and laid out for this purpose (NAS).  The drive carrier frame needs to be a bit stiffer (rolled edges would help here) because it depends on the drives for stiffness and proper shaping.  The two orientation nubs have to be "helped" to get the drive carrier frame mounted and that's a bit of a pain with 3.5" drives installed.
A simple one page sheet with recommended drive orientation would be helpful also.  If you put the drives in with the SATA connector end towards the RockPRO64 end of the case, the cables bind against the SATA HBA.
Once that is sorted, things fit very well and the case is very sturdy.
The outstanding issues in my mind for now are -
- The light pipe is pretty useless unless the unit is in a dark room
- The unit should include a proper case fan as part of the base package
- The drive carrier frame needs its edges rolled to both add needed stiffness and save our fingers
Other than those three items, this is a perfect solution for use as a media server in a home environment or a small workgroup file server.  I've currently configured it with two 12TB Seagate He drives striped using mdadm for speed and capacity.
Performance tests will follow.
Received my NAS case - by Tim Jones - 06-20-2019, 11:16 AM
  NAS case HDD power cable failure (buck failure) ashleymills 1 1,917 04-01-2022, 11:25 AM
Last Post: ashleymills
  Plugging In Case Fan and CPU Fan publiclewdness 0 1,432 01-04-2022, 09:58 AM
Last Post: publiclewdness
  Nas Case out of stock Goffi 2 2,278 12-04-2021, 05:14 AM
Last Post: Goffi
  RP64 TV box case with wifi Wizzard 2 3,298 03-10-2021, 12:23 AM
Last Post: Wizzard
Question 1U Rackmount Case for ROCKPro64 tuaris 3 5,027 02-18-2021, 08:09 PM
Last Post: TRS-80
  NAS Case: Issues with hardware installation, esp. screws kuleszdl 0 1,734 01-09-2021, 05:24 PM
Last Post: kuleszdl
  case for RockPro64 + PCI-E M.2 NVMe Card? AndyOfLinux 9 12,728 01-05-2021, 05:05 PM
Last Post: kuleszdl
  Release CAD files for NAS case or parts of it? diizzy 5 5,514 08-13-2020, 04:50 AM
Last Post: diizzy
  Best location for adhesive wifi antennas with NAS case callegar 1 3,072 02-17-2020, 12:40 PM
  RP64 NAS Case, 1 month in Tim Jones 1 2,916 07-29-2019, 04:16 PM
Last Post: Luke
