Pine hangs up on boot if I add my exFAT USB drive to /etc/fstab
I can mount it manually fine off the CLI but if I add it to /etc/fstab it hangs the entire system when booting. I've got it on fstab as
/dev/sda2    /mnt/verbatim    exfat    defaults    0    1
Am I missing something in the options? Is it just checking something on boot and taking a long time? (it's a 2TB drive)
Given that it works if I mount it manually, I'm not sure what I'm doing wrong here  Sad
EDIT: setting pass to 0 and changing defaults to rw,auto,user,gid=1000,uid=1000 seems to have fixed it. I'm not 100% sure but I suspect it may have been the pass going to 0 that did it (as noted earlier in my original post, it's a 2TB USB3.0 drive and checking that filesystem would certainly have taken a long time). This means I have to be more hands-on about checking and maintaining the file system, but at least it now boots and mounts it correctly.
Pine hangs up on boot if I add my exFAT USB drive to /etc/fstab - by pqueiro - 06-10-2019, 12:07 PM
  Pine 1 will no longer boot (bricked) dstallmo 0 1,309 06-22-2023, 12:22 PM
Last Post: dstallmo
  Xenial Minimal Image (PINE A64(+)) 0.6.2-77 pineadmin 4 21,679 08-30-2020, 10:35 AM
Last Post: jrronimo
  Successful build on arm64 pine a64 1GB on armbian alladinrouteme 1 4,073 09-23-2019, 03:30 AM
Last Post: cr2016
  +LTS/SOPINE Compilation procedure for U-Boot and Linux for pineA64 LTS. danpurprakash@gmail.com 1 4,183 06-05-2019, 11:50 PM
Last Post: igorp
  Pine Board using linux stuck during boot sequence ktaragorn 0 2,822 03-23-2019, 04:06 AM
Last Post: ktaragorn
  PINE A64 upgrade to 18.04 possible? RandomUser324 4 9,381 11-29-2018, 11:46 PM
  Resize /Boot mmcblk0p1 on SD? chadc 7 11,216 08-24-2018, 01:23 PM
Last Post: goathunter
  Ubuntu boot very slow with wifi driver remainder 9 20,903 08-03-2017, 07:23 AM
Last Post: victorssantos
  Xenial Minimal Image (PINE A64(+)) 0.5.5-65 pineadmin 0 4,128 06-15-2017, 12:37 AM
Last Post: pineadmin
  Xenial Minimal Image (PINE A64(+)) 0.5.2-59 pineadmin 0 3,813 05-25-2017, 09:27 AM
