RPi.GPIO python module for Pine A64/A64+
#57
(08-16-2016, 06:15 AM)DonFL Wrote:
(08-10-2016, 04:53 PM)MarkHaysHarris777 Wrote: @DonFL, confirmed:
GPIO.setmode(GPIO.BOARD)
GPIO.setup(40, GPIO.OUT)
... will get an error channel not valid on a Raspberry PI.  Either the RPi.GPIO-PineA64 codes were ported from the 26 pin GPIO stuff... or else, this is an over-sight (a bug, for sure).
The work-around (as DonFL has noted) is to code  GPIO.setmode(GPIO.BCM).  then all of the channels may be setup, with the exception that some of the channels (GPIO04) apparently do not work.  Need to dive into the code to find out, because that doesn't make any sense.
This issue has been fixed. Updated code is at the github location:  https://github.com/swkim01/RPi.GPIO-PineA64
Thanks much, Don, for reporting it and for the update...   i really appreciate it !
RE: RPi.GPIO python module for Pine A64/A64+ - by MarkHaysHarris777 - 08-16-2016, 08:15 AM
  fm transmitter with gpio weasel18 2 4,877 09-10-2019, 04:28 AM
Last Post: desai_amogh
  How to use dts or other setup to declare gpio pin Interrupt (e.g. a button)? dkebler 1 3,630 06-12-2019, 10:37 AM
Last Post: dkebler
Lightbulb Sample GPIO codes highlighting RPi.GPIO-PineA64 and the PI bus MarkHaysHarris777 6 11,223 06-07-2019, 12:37 AM
Star GPIO, SPI and I2C C++ Lib databit 7 11,321 02-04-2019, 05:45 AM
Last Post: Jeff R
Information Howto: Controlling Pine64 GPIO via the filesystem (sysfs) on linux pfeerick 4 11,941 01-24-2019, 03:36 AM
Last Post: Fifth
  GPIO and SPI SamR1 20 31,895 03-15-2018, 10:32 AM
Last Post: jomoengineer
Question GPIO shockr 7 14,889 03-11-2018, 01:52 AM
  Read GPIO problem shworker 14 21,351 08-17-2017, 01:21 PM
Last Post: martinayotte
  Cross-wired Uart Ports between two Pine Boards via Cat5 Cable MarkHaysHarris777 10 16,147 11-20-2016, 04:17 AM
Last Post: pfeerick
  GPIO fiq capability joseph 3 6,158 11-10-2016, 06:07 PM
Last Post: joseph
