Debian build from mrfixit2001
(07-26-2020, 08:01 PM)dkking Wrote:
(06-24-2020, 04:33 PM)schmidtbag Wrote: I used this disk image since the one by ayufan wouldn't boot.  It works fine and after a couple days I got everything set up the way I want, only to realize this is stuck at the same kernel version.  Not only that, but but this appears to be running as armhf, instead of arm64.  I'm really hesitant to just install the latest linux-image package because in my experience with other ARM systems, overriding a fixed kernel like that usually results in bricking the whole install.
I'm not using a GUI, so if upgrading the kernel means breaking the GPU drivers, that's fine - I don't care.  Anyone know if I can safely upgrade the kernel, let alone convert my setup to arm64 (I realize doing that would involve replacing just about every single package; that's fine)?
i was able to update to the latest ayufan one with a workaround discussed here
on kernel 5.6 now, start from 0.9.16 arm64; update and upgrade using the procedures mentioned and it should get you there.
Funny - that solution seems pretty obvious.  I'd have likely done the same thing, if I didn't have the mrfixit disk image to try.  But I really don't want to start all over again reconfiguring everything.  At the very least, I'd like to use the disk image I currently have and just upgrade the kernel without bricking it.  If I'm stuck with armhf, that isn't such a big problem for me, because aside from some MySQL commands, I overall don't think I'll see any performance improvements.  In some cases, 64-bit is actually slower on ARM.
Debian build from mrfixit2001 - by Luke - 02-25-2019, 05:28 PM
RE: Debian build from mrfixit2001 - by fredvej - 02-27-2019, 04:29 PM
RE: Debian build from mrfixit2001 - by dkking - 03-10-2019, 03:59 AM
RE: Debian build from mrfixit2001 - by pineadmin - 05-27-2019, 11:58 PM
RE: Debian build from mrfixit2001 - by S_Paul - 06-04-2019, 03:14 AM
RE: Debian build from mrfixit2001 - by hmuller - 06-05-2019, 09:30 AM
RE: Debian build from mrfixit2001 - by S_Paul - 06-05-2019, 08:24 PM
RE: Debian build from mrfixit2001 - by pineadmin - 06-19-2019, 01:55 AM
RE: Debian build from mrfixit2001 - by JCMPine64 - 06-21-2019, 01:20 PM
RE: Debian build from mrfixit2001 - by Enig123 - 04-27-2020, 01:35 PM
RE: Debian build from mrfixit2001 - by FeMike - 02-11-2020, 04:04 PM
RE: Debian build from mrfixit2001 - by schmidtbag - 06-24-2020, 04:33 PM
RE: Debian build from mrfixit2001 - by dkking - 07-26-2020, 08:01 PM
RE: Debian build from mrfixit2001 - by schmidtbag - 07-27-2020, 06:13 AM
RE: Debian build from mrfixit2001 - by Wizzard - 05-14-2021, 05:10 AM
RE: Debian build from mrfixit2001 - by Wizzard - 05-17-2021, 02:35 AM
  How to update/compile Debian 12.5? Wizardknight 3 579 03-29-2024, 05:01 AM
Last Post: gedas07
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,779 10-12-2023, 05:14 PM
Last Post: tpaul
  rock64-debian-mrfixit-190531.img.xz : missing /usr/lib/dri/rockchip_dri.so popi 5 5,388 08-12-2021, 04:55 AM
Last Post: igorp
  Debian kernel stuck at 4.4.167 Enig123 5 5,754 12-29-2020, 12:57 PM
Last Post: kwinz
  Debian (Vanilla) on Rock64 and eMMC - how ? as365n4 4 5,374 09-21-2020, 04:33 AM
Last Post: as365n4
  pcsx rearmed on rock64 debian stretch does not go fullscreen RockyBoulder 2 4,283 05-09-2020, 03:15 AM
Last Post: lawrencejd
Question alternative browser / seamonkey armhf build? kapqa 1 2,927 03-26-2020, 03:02 AM
Last Post: kapqa
  csdr build issues. TravisH 0 2,002 02-19-2020, 04:47 AM
Last Post: TravisH
  Fedora 31 crosscompilation fdt problem mimics debian 888789 kf5zmi 2 4,233 01-20-2020, 12:25 PM
Last Post: kf5zmi
  Upgrading Debian Stretch image to Buster cosuhi 2 4,799 08-27-2019, 02:42 AM
Last Post: Malmgren
