csdr build issues.
Hi All,
I am very new to the rock64 and am trying to set up a webSDR using the HackRF. I am having a few issues with building the source though.
I run the make and get the following errors;
gcc -std=gnu99 -O3 -ffast-math -fdump-tree-vect-details -dumpbase dumpvect -mfloat-abi=hard -march=armv7-a -mtune=cortex-a72.cortex-a53 -mfpu=neon -mvectorize-with-neon-quad -funsafe-math-optimizations -Wformat=0 -DNEON_OPTS fft_fftw.c libcsdr_wrapper.c  -g -lm -lrt -lfftw3f -DUSE_FFTW -DLIBCSDR_GPL -DUSE_IMA_ADPCM -Wno-unused-result -fpic -shared -Wl,-soname,libcsdr.so.0.15 -o libcsdr.so.0.15
gcc: error: unrecognized command line option '-mfloat-abi=hard'
gcc: error: unrecognized command line option '-mfpu=neon'
gcc: error: unrecognized command line option '-mvectorize-with-neon-quad'
Makefile:52: recipe for target 'libcsdr.so' failed
make: *** [libcsdr.so] Error 1
The inbuilt PARAMS_NEON is set as PARAMS_NEON = -mfloat-abi=hard -march=armv7-a -mtune=cortex-a8 -mfpu=neon -mvectorize-with-neon-quad -funsafe-math-optimizations -Wformat=0 -DNEON_OPTS
What should this be changed to to suit the Rock64 board?
If it helps, I am running aarch64-linux-gnu, Ubuntu minimal 64 bit (18.04)
Many thanks!
  USB3.0 Issues at DietPi(Armbian) #22.02.1 t4_4t 3 2,376 08-15-2022, 06:58 PM
Last Post: TRS-80
  Debian build from mrfixit2001 Luke 18 27,295 05-17-2021, 02:35 AM
Last Post: Wizzard
Question alternative browser / seamonkey armhf build? kapqa 1 2,889 03-26-2020, 03:02 AM
Last Post: kapqa
Rainbow USB3 Detection Issues When Booting Without USB Device Attached Dargmuesli 0 1,980 01-14-2019, 11:26 AM
Last Post: Dargmuesli
  Seedbox issues (rtorrent, rutorrent, autodl-irssi) va88 5 7,483 12-16-2018, 10:59 AM
Last Post: va88
Question Build Linux OS with Yocto RuslanGennadievich 1 4,476 10-06-2018, 07:12 AM
Last Post: miche
  Kernel Build Help frewind 26 27,562 08-12-2018, 12:46 PM
Last Post: cooker
  Arch Linux USB3 Issues? decontainerized 4 7,687 07-25-2018, 04:39 AM
Last Post: cooker
  Ubuntu Core build vivek_kaloliya 1 3,024 06-08-2018, 05:11 AM
Last Post: Matthew
  monitor setting & keyboard issues gpine1 2 3,369 05-27-2018, 03:51 PM
Last Post: Luke
