USB3 Detection Issues When Booting Without USB Device Attached
Rainbow
Hey there,
I received my Rock64 about a week ago and I have been trying to get a consistent USB3 connection to work since then. I've tried multiple OSs, ports and devices and spent many hours googling.
What I've found out: booting without a USB device connected results in no USB3 device detection on later plug in into the USB3 port. USB3 into USB2 port works, USB2 into USB3 port works. But USB3 on USB3 does absolutely nothing. No output with
lsusb -t
and
lsblk
Now - after initiating a return, because I suspected a hardware failure - I've found that booting with any USB device connected to any USB port results in normal device detection afterwards. Even plugging devices in and out in any combination works flawlessly then.
... what?! Can somebody explain to me what is going on here, because the return packet is already paid. If it turns out to be fixable through software, I'd need to cancel the refund task. I'm currently on
Linux DietPi 4.4.132-1075-rockchip-ayufan-ga83beded8524 #1 SMP Thu Jul 26 08:22:22 UTC 2018 aarch64 GNU/Linux
Thanks in advance!
  Swap/Upgrade Storage Device? r00t3d 0 652 08-17-2022, 06:11 AM
Last Post: r00t3d
  USB3.0 Issues at DietPi(Armbian) #22.02.1 t4_4t 3 2,266 08-15-2022, 06:58 PM
Last Post: TRS-80
  Buildroot 2021.08 not booting from SD card jimmy 1 1,940 11-08-2021, 02:25 AM
Last Post: hunderteins
  Booting from USB 3 SSD with other drives attached. default_user8 0 1,664 02-20-2020, 08:39 AM
Last Post: default_user8
  csdr build issues. TravisH 0 1,937 02-19-2020, 04:47 AM
Last Post: TravisH
  Forcing u-boot to detect USB3 storage jandastroy 8 11,098 04-02-2019, 10:06 PM
Last Post: t4_4t
  Seedbox issues (rtorrent, rutorrent, autodl-irssi) va88 5 7,335 12-16-2018, 10:59 AM
Last Post: va88
  USB3 problems scalextrix 2 3,976 09-08-2018, 01:15 AM
Last Post: scalextrix
  Rock64 - can not connect via store's USB-to-serial nor see (if) booting. jovval 5 5,775 09-06-2018, 07:06 AM
Last Post: jovval
  Rock64 USB3 bugs NitroDeath 4 7,813 09-02-2018, 03:00 AM
Last Post: NitroDeath
