[SOLVED] Can't boot when SD card inserted
Perhaps you have already tried this, but if you remove the SD card, will it boot off of the eMMC?
It appears that the Pinebook has a boot order, of SD slot, then eMMC. Not sure if this can be changed (or if it is a good idea to change it)
RE: Can't boot when SD card inserted - by cvmiller - 11-16-2018, 07:00 PM
RE: Can't boot when SD card inserted - by jschall - 11-17-2018, 07:18 AM
RE: Can't boot when SD card inserted - by jschall - 11-17-2018, 09:21 AM
RE: Can't boot when SD card inserted - by jschall - 11-17-2018, 11:53 AM
  Booting with TOC0 u-boot -- should it work? dreadbit 0 792 11-24-2022, 10:19 AM
Last Post: dreadbit
  Few questions about flashing to a MicroSD card on the Pinebook Pro SanjevR 6 9,956 12-07-2020, 04:02 PM
Last Post: SanjevR
Lightbulb Boot from SD card / boot options lodger 13 24,436 11-26-2019, 07:14 AM
  eMMC boot linux distros for Pinebook. frank-zappa 14 21,144 09-06-2019, 08:39 AM
Last Post: frank-zappa
  Link to 11.6 pinebook mainboard schematics for removing wifi card Shoananas 0 2,016 05-19-2019, 04:46 PM
Last Post: Shoananas
  Is it possible to choose between SD/eMMC boot programmatically? UltraBloxX 2 4,907 01-28-2019, 11:41 AM
Last Post: UltraBloxX
  Boot from MicroSD ramboton 3 5,485 11-16-2018, 06:04 PM
Last Post: Luke
  [SOLVED] HELP! Four clocks on panel! jschall 2 3,745 11-16-2018, 09:55 AM
Last Post: jschall
  How to mount new microSD card? jschall 8 8,926 11-12-2018, 11:04 AM
Last Post: jschall
  Move Installation from SD Card to eMMC? soupbowl 4 8,914 11-10-2018, 10:47 AM
Last Post: acruhl
