Is it possible to choose between SD/eMMC boot programmatically?
Hello! I would like to dual-boot two distros on Pinebook, e.g. one on eMMC + one on microSD, but apparently, microSD takes the priority and as long as it's inserted - will boot first. Removing/reinserting SD just to force eMMC boot is inconvenient for me (very short nails, need to find something to push SD) and would be unwanted stress on SD slot. Is there a way to choose eMMC boot from u-boot?
(01-27-2019, 03:13 AM)UltraBloxX Wrote: Is there a way to choose eMMC boot from u-boot?
Yes ! With Armbian u-boot, stop u-boot early to get into command prompt, then use the following commands :
mmc list setenv devnum X   (where X is the eMMC number shown in previous list) run mmc_boot
martinayotte, huge thanks!  Smile
  Booting with TOC0 u-boot -- should it work? dreadbit 0 3,769 11-24-2022, 10:19 AM
Last Post: dreadbit
  Pinebook with a broken screen and 2 eMMC's for sale. UK ONLY. frank-zappa 0 5,589 03-08-2022, 10:14 AM
Last Post: frank-zappa
  How to transfer customised OS from SDcard to emmc quixote 1 9,463 01-07-2022, 06:38 AM
Last Post: alanwake82
  eMMC backup milkaca 19 44,950 04-08-2020, 07:35 PM
Last Post: adamz
Lightbulb Boot from SD card / boot options lodger 13 37,850 11-26-2019, 07:14 AM
  eMMC boot linux distros for Pinebook. frank-zappa 14 33,525 09-06-2019, 08:39 AM
  These fell out of my Pinebook when I tried to replace the eMMC. frank-zappa 6 13,766 03-02-2019, 06:51 AM
  [SOLVED] Can't boot when SD card inserted jschall 5 14,027 11-17-2018, 11:53 AM
Last Post: jschall
  Boot from MicroSD ramboton 3 9,060 11-16-2018, 06:04 PM
Last Post: Luke
  Move Installation from SD Card to eMMC? soupbowl 4 14,074 11-10-2018, 10:47 AM
Last Post: acruhl
