RockPro64 power consumption
Hi
I have both 4GB ROCKPro64 and 4GB Rock64. I have to use both in a wireless kind of environment or locations where grid electricity is not there.
I have tried Rock64 with Portable power bank giving 2.1A current using USB to 3.5mm OD/1.35mm cable and it worked well.
I was wondering what minimum power i can give to RockPro64 without damaging it ? Most commercial power banks gives 2.1 A current with 5V USB cable. I have searched Amazon and could see some portable power banks with variable current options higher than 2.1 A but indeed they are expensive. Giving higher current using USB cable is fine .. ? Please advise what should i do to make ROCKPro64 portable.
If someone can recommend a solar power charger that can work, that will be an added advantage ... All green energy setup Big Grin
RockPro64 power consumption - by seiji - 08-02-2018, 11:56 AM
RE: RockPro64 power consumption - by Bullet64 - 08-02-2018, 01:22 PM
RE: RockPro64 power consumption - by dukla2000 - 08-02-2018, 06:34 PM
RE: RockPro64 power consumption - by seiji - 08-03-2018, 10:11 AM
RE: RockPro64 power consumption - by dukla2000 - 08-04-2018, 03:40 PM
RE: RockPro64 power consumption - by lucho - 08-11-2018, 12:54 AM
RE: RockPro64 power consumption - by TOMillr - 08-13-2018, 03:24 AM
RE: RockPro64 power consumption - by lucho - 08-15-2018, 07:43 AM
RE: RockPro64 power consumption - by dukla2000 - 08-15-2018, 12:11 PM
RE: RockPro64 power consumption - by waqasnasir - 03-30-2019, 02:02 PM
RE: RockPro64 power consumption - by evilbunny - 03-30-2019, 03:32 PM
RE: RockPro64 power consumption - by pfeerick - 03-30-2019, 11:15 PM
  power button not working Vista8720 0 191 05-07-2024, 11:26 PM
Last Post: Vista8720
  Installing Wifi drive for the RockPro64 John45595 0 355 02-10-2024, 11:32 PM
Last Post: John45595
  enble boot after power loss/restore dkebler 18 9,872 12-04-2023, 12:14 PM
Last Post: ok38
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 831 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 719 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 4,391 07-14-2023, 08:59 AM
Last Post: rockjonn
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 935 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
  No sound on Rockpro64 with OpenWrt Patrice 1 1,383 04-06-2023, 02:46 PM
  Cant get rockpro64 working brasilikum 3 1,901 03-19-2023, 06:22 AM
Last Post: runyor
  RockPro64 Stopped working WarpLover 5 2,785 02-06-2023, 10:10 AM
Last Post: diizzy
