Status PCIe slot and the SATA interface card
#22
(05-28-2019, 08:32 AM)vecnar Wrote: I have a cheap infrared thermometer and it was showing at the start 24 degrees celsius and  32 degrees after beeing on for around 10 minutes. When trying to copy light amounts of files the same temperatures are reported.
Thank you for update. Now it is obvious that the temperature definitely not is the cause.
RE: Status PCIe slot and the SATA interface card - by Nikolay_Po - 05-28-2019, 02:22 PM
  AW-CM256SM wifi card mtek 4 2,423 10-30-2023, 12:00 PM
Last Post: diederik
  Which SATA card should I use my NAS server RAID5 Louysa 3 929 09-24-2023, 04:40 AM
Last Post: JPT223
  SATA keeps crashing JPT223 1 576 09-21-2023, 10:52 PM
  SATA hotplug not working? JPT223 0 451 09-15-2023, 04:20 AM
Last Post: JPT223
  Compatible PCIe Sata Controller spacebricker 1 1,587 02-06-2023, 10:03 AM
Last Post: diizzy
  ROCKPro64 with 16 ports SATA controller ZeblodS 19 26,016 12-18-2022, 06:25 PM
Last Post: heyghoge
  PCIe bifurcation support (on RK3399) Arn 1 1,356 11-28-2022, 05:12 PM
  Full Size Bracket for the NVME PCI-E Card publiclewdness 0 1,394 12-31-2021, 12:53 AM
Last Post: publiclewdness
  Existings disks and using a StarTech SATA Controller jkugler 1 2,105 12-09-2021, 06:41 AM
Last Post: SVDSHRDJD
  RockPro64 doesn't boot when PCIe to M.2 adapter is installed Cerberus 3 3,542 11-27-2021, 11:38 PM
Last Post: Cerberus
